Ticket Created
WERETECH-10039
ANT+ Battery Status
The latest in the saga for Battery Status. I used an ANT+ dongle on my Windows Laptop, and paired it with the Eclipse Simulator. I tried both an older Garmin Cadence Sensor, and a brand new one (the one that does both ANT and BT). Same outcome. In both cases, the CIQ data field immediately gets Device State info. After maybe 30-40 seconds, the ProductInfo.serial number comes thru. Just like in real life when paired to a real Garmin Edge computer. But in both cases, even after several minutes, the Battery Status remains null.
When I pair the new cadence sensor to my actual Garmin Edge computer, the Battery Status does come up as OK within 15 seconds or so and then maybe 30 seconds later the Serial # info comes through.
Any clue why the polling code isn't seeing the Battery Status?
Oh, also, the State Update Listener is triggering, but the BatteryStatusListener is not.
Parents
  • [quote userid="43945" url="~/developer/connect-iq/f/discussion/245190/ant-battery-status/1163666"]I joined the ANT+ developer's group, so I imagine the details are in one of their documents. You have a lot of experience with this stuff. Any tips? Thanks!![/quote] By Ant+ developer's group, do you mean registering to thisisant.com? If yes, that is the correct place, documents for Ant+ profiles are here. In those you have description of each page content for each profile: www.thisisant.com/.../  In this case for page 82 (described in Common Data Pages doc, as well as in Shifting profile doc), you have battery identifier in byte 2 (values 36 or 68):
    Identifies the battery in system to which this battery status pertains and specifies how many batteries are available in the system.
    Bits 0 – 3: Number of Batteries
    Bits 4 – 7: Battery Identifier(Refer to Table 6-3)
    Set to 0xFF if not used.
    Why the status is 1 'new', again it is up to sensor manufacturer.
Comment
Children
No Data
