Acknowledged
all course point distances are set to zero
All course point distances in Garmin Edge 1040 are set to zero. FW version 16.13.
It seams to be a CIQ bug (previously, when the GPX was imported to CIQ and the exported as GPX, it had the same order of the course points; now the course point order is changed in the export GPX file).
Process:
- use Garmin Connect PC app (browser version)
- import course from GPX file
- course points are shown in the map
- send the course to the device via Garmin Express
- select the course in the device / Ride
- the device beeps and shows sequentially all course point names
- in the course point screen there are all course points with distance = 0
- the only c. p. with distance is the finish course point
Note: Old course (imported about 1 month earlier) has course points OK with distances, so it is probably not the device FW issue.
