Acknowledged
Adding Fit Contributions to an existing datafield increase the PRG build time extremly
I added 3 fit contributions to my existing datafield „Edge AllinOne1“
and that increased the build time for the prg file from 15 seconds to 5 minutes!
https://apps.garmin.com/en-US/apps/cd433835-4089-476b-a0cf-0c13db63a18c I then did some tests and added the fit contributions one by one -
here is the result for build time:
-no Contribute at all: build time: 15 seconds -added one Contribute: build time: 1:15 minute -added 2 Contributes: build time: 2:20 minutes -added all 3 Contributes: build time 5 minutes If you want to investigate the case further, please send me a PM or an email. I would then send you the project for further investigation. Here is the code to comment out or take in contribute by contribute:
        // CONTRIBUTION+++++++++++++++++++++++++++++++++++++++++++++++++++++
        if ( showBatteryGC == true )    {
            mybatteryField = createField("devicebattery", batteryID,  FitContributor.DATA_TYPE_UINT8, {:mesgType=>FitContributor.MESG_TYPE_RECORD, :units=>"%"} );
            if ( mybatteryField != null ) {
                mybatteryField.setData(0);
        if ( showShiftGC == true and gearArt > 0 )    {
            if ( gearArt == 3 ) {       // front Gear
                myfshiftField = createField("frontShift", fshiftID,  FitContributor.DATA_TYPE_UINT8, {:mesgType=>FitContributor.MESG_TYPE_RECORD, :units=>"Idx"} );
                if ( myfshiftField != null ) {
                    myfshiftField.setData(0);
            myrshiftField = createField("rearShift", rshiftID,  FitContributor.DATA_TYPE_UINT8, {:mesgType=>FitContributor.MESG_TYPE_RECORD, :units=>"Idx"} );
            if ( myrshiftField != null ) {
                myrshiftField.setData(0);
        // ENDE CONTRIBUTION+++++++++++++++++++++++++++++++++++++++++++++
  • Remark to Lenovo laptop: when compiling the vent goes up and makes noise - device seems very busy…
    Thank you for testing!
    Strange - but that gives hope...
    >>>That being said, what versions of Java JDK do you have installed on your machine and what type of compiler / vscode extension settings are you using?
    1) JAVA:
    I'm using Oracle Java 1.8.0_361-b09
    But I've tried other versions for testing compiler time (to no avail):
    Eclipse JDK17.0.8_7:  5 min 30 sec    (JDK because I simply accepted the suggestion for my OS)
    Oracle Java 8_241:  4 min 35 sec
    Oracle Java 8_361: 5 min 00 sec
    3) OS - Windows:
    MS WIN10 Pro  Vers.  22H2
    3) VS Code:
    VS-Code 1.81.1
    (all settings are default - I did not change anything after installation)
    3) Monkey C Extension:
    Version 1.0.9
    OptimizationLevel: Default
    Type Check Level: Default
    I just set OptimizationLevel to Fast - little difference in build time: 4:30 minutes
    4) Laptop:
    Lenovo ThinkPad T570, i5-7300U, 8 GB RAM
  • I've received your project and have compiled it dozens of times with various levels of optimization and in debug / release and average 6 seconds regardless of the amount of fit contributors. I'm going to send this to our compiler development team to see if they can track down what might be happening. Perhaps some specific Java version or setting could be causing something.
  • Apologies about the late response. You can send any documents to [email protected] and we will look into it.
  • Thank you. I would like to share my project - please send an email or PM with your email to send a zip file.
