Hi Garmin Connect IQ Team,
I'd like to follow up on JPEG bitmap packing format support for the Instinct 3 AMOLED series.
I recently purchased an Instinct 3 AMOLED 45mm and noticed a significant difference in the installation size of a third-party watch face, Rad-Lad 2:
Regular version: 964 KB
Touchscreen-less version for Instinct 3: 7.93 MB
I contacted the developer directly, and they explained that both versions share the same codebase, but the Instinct version cannot use JPEG compression and therefore uses PNG images instead.
This results in an application size more than eight times larger.
I'd appreciate clarification on the following:
Is the lack of JPEG bitmap packing support a hardware limitation, a firmware limitation, or an SDK limitation?
Are there any plans to improve image compression support for the Instinct 3 AMOLED series?
Are there any recommended alternatives for developers to reduce bitmap resource sizes on these devices?
Improving image compression support could benefit both Connect IQ developers and Instinct users, particularly for applications with extensive graphical assets.
Thank you for your time and support.
Relevant applications:
https://apps.garmin.com/apps/da9a6208-23e5-4853-b3fd-9c8e12955ded
https://apps.garmin.com/apps/4c85a08b-be92-4aaf-963e-5187df34fae3
