Acknowledged
CIQQA-4127
Add device identifier variable to Monkey Jungle
It would be very helpful if Monkey Jungle provided a built-in variable for the target device identifier (e.g. fr255, fenix7) during the build process. Currently, device-specific handling often requires defining paths per device. Introducing a predefined variable such as $(device) that resolves to the current target device would enable dynamic inclusion of device-specific directories in source and resource paths and remove the need to define paths separately for each device.
For example:
base.sourcePath=somedirectory/$(device)
Parents
  • Having a bunch of different source files sounds like it would make support pretty messy.
    Why not limit the source file and use annotations/ "has" to reduce this?
    why does the epix2pro47mm need its own source files, for example?
    I have apps that I started back when there were only a few CIQ devices, that today also support the latest, all using the exact same source files.
Comment
Children
No Data
