Ticket Created
WERETECH-9131
ActivityMonitor Info Editor: Steps don't reset at midnight
It would be useful for the DataField I'm working on (which records steps for an activity) to be able to simulate a walk that crosses over midnight and has the step count reset to zero. There seems to be no way to simulate this behaviour at present - I tried setting my system clock to 23:59 and also "Fast Forwarding" the activity monitor by 1500 minutes - in both cases the step count just kept going up. You definitely shouldn't have to mess with the system clock to get this feature to work either - it should happen on the back of Fast Forwarding, or else there should be a menu option to simulate the end of the day occurring. Perhaps there actually is - I see there's a "Time Simulation" menu option but it seems permanently disabled and I've never worked out why. Is it only for watch faces?
  • Time simulation is only for watch faces.
    I added something similar to some device apps a few years back, and if I recall, the way I tested it was on a real device, where I would manually set the time on it so I could watch what happened at midnight.
    It would be nice if there was a way for the steps to reset at midnight in the sim.
