Acknowledged
3rd part Data Fields on Venu Sq have unreadably small font
I tried installing Calculate Formula and AppBuilder5 datafields. They both show the calculated data in a very tiny font.
I contacted both the developers and was told by the CalculateFormula developer that the font size is fixed for simple data fields.
This seems to be a problem for Venu Sq watches.
Parents
  • is there anyway to get sum(hr > 160) to return a number and hence use the bigger font??
    Actually AppBuilder 5 returns a numerical value as long as your formula is purely numerical, and your display format is Auto, Number or Decimal. You could try changing the format to Number.
    If you still have the same problem, then I would say it's a different than what I've described. I will say it's possible that there are two different (yet similar) issues here. The only one I could reproduce (and make an educated guess at understanding the root cause) was the thing where simple data fields that return strings now always use small fonts.
Comment
Children
