Watchface: GF3240 - Garmin Fenix3 240 degrees
This is a watch face inspired on a Moto screen mock(?). It shows the time on a 240 degrees scale instead of the common 360 degrees. For convenience there's also a digital time.
V1.3
- the performance of the watch should be ok now,
- added a background image for the static parts of the watchface.
- added the arc for battery percentage with a red triangle indicator.
- added the arc for daily step progress percentage with a blue triangle indicator.
V1.2
- removed the battery & step progress indicators. They made the watch respond sluggish.
V1.1:
- bug fix for the 12 hour clock.
- added small "arc" indicators for:
* battery (dark grey or red (<=25%)
* daily steps progress (white)
V1.0:
- 12 hour clock has AM/PM indicators
- 24 hour clock changes clock marks from 0-12 to 12-24
- second hand omitted, because there's no use for it in low power mode
- shows day, day of the week and month
source code: https://bitbucket.org/ajouwens/gf3240
    I love this face. My only question is why is the minute hand short and the hour hand long? It is kind of confusing.
    @rbergin: Thank you for the complement.
    When you want all the hours marks visible, an inner circle is too "crowded" to show them all. The only solution I could come up with was to change the hour and minute hand.
    I think this is OK, because most of us will still have to look twice to get the current time :rolleyes:.
    Hi Arjo,
    This is a wonderful watch face, congratulations!!
    I just wanted to point out that I'm experiencing that my watch behaves slower than before. For example, when I receive a notification it immediately vibrates but it takes at least 3 seconds to show the message on screen. Or when I press the menu button is even more noticeable, taking up to 8-9 seconds to open the menu.
    Are you also experiencing this delay?
    I tried many watch faces and it's the first time it happens to me.
    Keep the good work!!
    Hi ROCKYMATU,
    thank you for leaving a reply.
    I also noticed a delay in the behaviour of my watchface, but I thought it had to do with the software update I installed at the same time.
    Good to hear your remarks on this issue, and I will certainly look into it.
    Best regards,
    Arjo
