WatchApp: EnGarde
A simple application for timing and scoring a fencing bout.
Further details may be found on the EnGarde store page.
Please reply here with bug reports and feedback.
    Very good app! Please add function!
    Very good app! I'm a fencer (épée) with a Vivoactive v 3.00.
    I like this app, why doesn't insert more functions, as
    1. Matching count and automatic 1' rest (so first fraction, second fraction, third fraction and so on);
    2. Yellow and red card;
    3. Vibration when timer stops (not only in the end);
    Please continue to build and update the app! :)
  • Thank you!
    • When I get some time I plan to add the ability to choose timing configuration (for example 3 minutes for a simple match and then 3-1-3-1-3 for a full one).
    • I have considered this, but given the limited amount of screen space and accuracy with the touchscreen I'm not sure how to implement it. I wanted to keep timing and scoring as simple as possible but I will keep it in mind when adding stuff for #1.
    • Do you mean each time the timer is manually stopped?
    P.S. I'm a foilist :D
    1. Perfect!
    2. a.Maybe you could use the soft button on the down-right corner (the menu one) to insert the Yellow and the red card
    b.or try something 2-3-4 taps on the red or green fencer... But I don't know if the VA discrimates between three consecutively taps like one input or it will consider three taps as three inputs...
    c. Use the right and the left not-soft button to assign in the order Yellow-red-black. To star time you could use only the tap on screen solution.
    I don't know!
    3. Yeah! I think it's better, 'cause the referee could see the match and he doesn't need to check if timer is stopped or not (the vibration gives information to referee ;) )
    I hope you'll find time to work for the app!_
    Thanks very much however!
  • Fantastic tool for fencers! It makes timing and scoring so much easier during bouts.
    papa's games
    papa's games
