Widget: Battery Meter
Please use this thread to report any issues or problems you are having with the widget.
Battery Meter: https://apps.garmin.com/en-US/apps/5...a-f8bea4ca47d7
Battery Meter v2: https://apps.garmin.com/en-US/apps/e54849a1-cc77-4c6d-a01f-99b68e7503f2
DESCRIPTION:
Simple battery meter widget that displays a graphic battery meter and text representation.
INSTRUCTIONS:
Battery Meter:
  • Fenix/D2/920XT: Change the color scheme by selecting "Start/Enter" button.
  • Vivoactive: Change the color scheme by tapping the screen.
Color scheme will be remembered between widget uses.
Battery Meter v2:
Settings for color scheme are managed in Garmin Connect Mobile.
    After update it only shows IQ with !.
    It is not running any more.
    Vivoctice, 2.70
  • After update it only shows IQ with !.
    Vivoctice, 2.70
    I have reverted to the previous release. I have a fenix 3 so I will need to see if someone on the forums has a vivoactive and is willing to test and get me a error message to work from. It worked in the simulator provided for developers so I am not seeing the same thing you are. Thanks for reporting this.
  • I have reverted to the previous release. I have a fenix 3 so I will need to see if someone on the forums has a vivoactive and is willing to test and get me a error message to work from. It worked in the simulator provided for developers so I am not seeing the same thing you are. Thanks for reporting this.
    I believe the issue has been resolved and a new version has been published. Thanks!
  • The "bars" of the battery are outside of the battery icon on my Fenix 3. Any way to resolve this issue?
    Please disregard. I updated my Fenix 3 to the latest software and the issue was resolved.
    Color adjustment does not work with start button on Vivoactive.
    Also, I agree with reviews that say that the battery should show green when full and red only at 20%. The current view is confusing.
  • Color adjustment does not work with start button on Vivoactive.
    I was hoping you could confirm that you are using version 2.70 for the firmware on the Vivoactive: http://www8.garmin.com/support/download_details.jsp?id=7591. I would like to resolve the issue so it works correctly.
    The new green color scheme stays green till the last two bars and then turns red. The color schemes should give some different choices for people to use based on their preference.
    Vivoctice, 2.70
    Have you tried the new version and is it working again for you now?
  • Please disregard. I updated my Fenix 3 to the latest software and the issue was resolved.
    Glad to hear it is working now. Let me know if something isn't working right in the future with it.
    Yes, I am running v2.7. When I press the right side enter button, it just takes me to the activities page. Perhaps there is something I am missing about adjusting the colors, I can find any way to do it.
