Widget: Activity History
https://apps.garmin.com/en-US/apps/df50a873-3938-450f-ba06-934723a38781
This just shows the last week's history from the activity tracker. There are other widgets like it, but none for the Fenix 3 so I wrote this.
Press START to cycle through steps / distance / calories.
Changelog
1.1.3 - Remove workaround since it's now fixed in ConnectIQ
1.1.2 - Add workaround for ConnectIQ timezone bug
1.1.1 - Fix accidental upload of debug version :-)
1.1 - Visual tweaks
1.0 - Initial version
  • yup... it's fixed in my code as well. Tho I have to tweak it.
    Former Member over 10 years ago
    Any timeline for updated version for us normal users?
  • Trailing 7 day totals?
    Would it be possible to show a sum of the trailing 7 day totals at the bottom of the respective screens?
  • hi there,
    I have a problem with this widget. I install it to my f3 where I have a monday as a "first day of the week" and the widget still shows me "wrong" data. I don't know if it is connected with changed first day of week or something else.
    Example: It's friday and the widget showed me day history only from wednesday (and seven days before) but not thursday. Is it the same problem as Nikeow wrote?
    Thanks
    I don't know. It depends on if the app was doing anything to compensate for the bug. The start of day from activity monitoring history should return midnight local time for all entries now.
    The app was already compensating so it worked OK on older ConnectIQ but started to go wrong the other way round on 1.1.2+.
    I've now removed the workaround, hopefully that should fix it.
  • Any chance of an FR230/235/630 version ? Thanks !
    Former Member over 8 years ago
    Forerunner 735xt version?
    Would you be able to create a version that is compatible with the Forerunner 735xt? From what I understand the FR 735xt is running the same software as the fenix 3(?), so would it be possible?
