U R Here widget
Just a simple little widget that uses the new Mapping API in CIQ!
It gets your location, and then displays a map with a pin at your current location. You can optionally show the lat/lon, and based on watch settings for maps, will also show your saved user locations. Only available for devices with on board maps! When viewing the map, "start" takes you to browsw mode where you can pan/zoom, "back" exits the map.
U R Here
