- a readable time font
- sun events
- active statistics (heart rate / steps / stairs)
- YAHOO! weather & forecasts.
I have Venu 2, and am wondering if anyone else can see HR Line chart, if you set it for the bottom chart? It just shows a blank chart for me. If I choose e.g. Pressure line chart, it shows.
In Garmin Conenct Mobile (Android) you can select the apps that may send the messages to the watch.
That would be great! Thank you so much for your work.
should be fixed in v15.3
It works now! Thank you so much
Dear Peter
Thank you for the watchface, my wife and I are big fans! One question, is it possible to remove the enveloppe from the status symbols above? I like to see if I'm connected to Bluetooth or not, but I don't really understand the meaning of the enveloppe (I suppose messages on Whatsapp?) and I would like to turn this off. Is that possible without losing the bluetooth icon?
All the best
No it's not possible to individually turn it off. The envelope indicates all unread messages received on the watch, thus also includes messages from Garmin Connect eg when completing a run.
To remove the envelope you have to dismiss the messages. You can do so from within your garmin widget loop in the messages widget
I keep seeing the 'universal no' symbol (crossed out circle) in the top status icons up by Bluetooth/notifications/timers, but I can't find anything that tells me what that means! :)
It's the symbol I use for do not disturb state, it also shows during your sleep window
Ah!! YAY! Thanks for that. I hadn't been tracking when I was seeing it, but I just knew I couldn't recreate it at will...
I appreciate the response!
I am having trouble with the bottom chart body battery, I am unable to get the right statistics that the watch shows in the body battery section, I’m unsure if it’s showing either poor heart rate data or stress data with the wrong graph. Any help would be appreciated!
