- a readable time font
- sun events
- active statistics (heart rate / steps / stairs)
- YAHOO! weather & forecasts.
I have Venu 2, and am wondering if anyone else can see HR Line chart, if you set it for the bottom chart? It just shows a blank chart for me. If I choose e.g. Pressure line chart, it shows.
In Garmin Conenct Mobile (Android) you can select the apps that may send the messages to the watch.
Hi Peter,
I've looked through the settings and on here but I can't see a 24hr option. If this is not already part of the watch face I think it would be a great addition.
Thanks for your work, fantastic job on this and all your apps. All in One is all I use for my running
Cheers.
Not exposing this setting directly in Data Lover settings was one of the concessions I had to make to get all functionality within the available memory alotment (which is tight).
To change Data Lover to 24 hour mode go to your system settings of your watch and change the display to 24 hour mode (long press middle button to get to your watch system settings).
there's secondary time zone support, but you can only show this secondary time in the smaller data fields (eg below the time).
Hello, as it's hard to scroll through all the questions, I'm sorry if I ask something that have already been replied to.
I have set the Right Chart to Weather + City, but even if it shows the temperature, the information below is stuck on a strange "LFQA" cryptic message. I have set the Latitude & Longitude of my city, even tried to tick the "Allow lat/lon override by GPS" that doesn't change anything.
The watch is always BT connected to my phone, the Connect app always running. Please help :)
LFQA?
The city name is being provided by the weather provider, so a solution can be to switch to the weather provider in the data lover settings (Garmin Weather vs OpenweatherMap)
The city name is the location of the weather station, not your location.
Thanks for your answer.
I've tried to change the weather provider, but LFQA remains... It should be Reims, France.
Since LFQA is Reims Airport, that is actually quite accurate
Weird. I live in Bremen, Germany. Garmin Connect is set to a fix position (Bremen). If the weather station is at the airport, then I should see the ICAO-Code EDDW under the temperature, but it shows Bremen.
I don't know where the weather stations are, but they are not only at the airport ;)
The weather provider is passed the location of the last gps position (of last gps activity) and based on that position the weather provider chooses the closest weather station, the location shown is the location of the weather station.
