- a readable time font
- sun events
- active statistics (heart rate / steps / stairs)
- YAHOO! weather & forecasts.
I have Venu 2, and am wondering if anyone else can see HR Line chart, if you set it for the bottom chart? It just shows a blank chart for me. If I choose e.g. Pressure line chart, it shows.
hi Joerg, it's an issue on ios.
See https://forums.garmin.com/developer/connect-iq/i/bug-reports/broken-settings-in-connect-4-22-for-ios (and while you're there also upvote the bug report)
See faq q13 starttorun.info/data-lover
Hi! Thanks a lot for your watchface! I have tried to setup on the top right sunrise/sunset but I see only sunset time even after sunset. I would have expected to see sunrise time after sunset like in other watchfaces I used in the past.
Is it expected?
If it can help I am on a Forerunner 255 and I have set Sunrise/Sunset on “Field Top Right”. If I make it use it the top gauge then I see both sunrise and sunset but that’s not what I would like as it takes too much space
It's not expected. It should show sunrise time as soon as sunset time has passed.
Possibly this could be related with the issue where step history is not updating on some devices overnight (I'm currently investigating this one)
Thanks, I will double check today after sunset but if I recall correctly the steps are updated in my case
For the record nothing changed last night. Steps are being updated after sunset but the sunrise/sunset is stuck to sunset time
I used the altitude selection in one of my fields. I’m sat in a holiday home just up from a beach in Hawaii. The iPhone compass app shows 60ft which is reasonable but the watch face displays 959ft. Wondering where the watch face gets Altitude from. I’m using an iPhone XR and a Fenix 6x Pro.
Hi! If it can help I made another experiment to verify if the issue was on missing refresh of the field or not.
After sunset I tried to change the settings of the watchface forcing sunrise and then indeed it switched correctly to sunrise. Then, I switched back to sunrise/sunset, checking that if it was an update issue then sunrise would have been stuck on the watch. It instead switched back to sunset
if you don't have a bt icon it means it doesn't have connection to your phone. try one of the following:
- reboot phone and watch
- start gamin connect on phone
- as a last resort: factory reset watch
there's no city name for the second time zone, there's a possibility of "free text" but that can only be shown in the field just above the chart on the right.
