- a readable time font
- sun events
- active statistics (heart rate / steps / stairs)
- YAHOO! weather & forecasts.
I have Venu 2, and am wondering if anyone else can see HR Line chart, if you set it for the bottom chart? It just shows a blank chart for me. If I choose e.g. Pressure line chart, it shows.
In Garmin Conenct Mobile (Android) you can select the apps that may send the messages to the watch.
Hi Peter,
After your reply I did a test last night: the half circle bar was fully red before I reset it by moving around. After it was reset, I replaced the altitude field with hearth rate. This morning my watch warned me for being inactive, but the half circle stayed white.
fixed it I think. You can try the fix by downloading the public beta version of Data Lover
That is quick.
I have installed it, so I will get back to you soon.
Unfortunately another issue arose. The Move circles are now black, except the outer one. It does not matter whether the Move-alert is active or not, nor does adding the hearth rate field change anything.
Thanks for all the effort!
think this should be fixed now too in the new beta release.
to ensure you have the proper version:
- uninstall data lover public beta
- when using garmin express: disconnect usb cable from computer
- when using garmin express: connect usb cable to computer
- install data lover public beta
- apply your settings
Works like a charm
5JB16602V1805562B Is the tx #
both issues might be related as for both these things you need a gps location. start a run actiivty and wait for a green gps fix then return to the watch face. It might take till tomorrow before the new moon phase is calculated.
for the wind speed to be updated you need 4 requirements to fulfill, these are explained in the faq q1 starttorun.info/data-lover
