- a readable time font
- sun events
- active statistics (heart rate / steps / stairs)
- YAHOO! weather & forecasts.
I have Venu 2, and am wondering if anyone else can see HR Line chart, if you set it for the bottom chart? It just shows a blank chart for me. If I choose e.g. Pressure line chart, it shows.
In Garmin Conenct Mobile (Android) you can select the apps that may send the messages to the watch.
Try to uninstall and reinstall data lover (sometimes upgrading the app does not work properly)
the bottom graph got refactored, sometimes the upgrade of a previous version doesn't handle this properly.
to fix: uninstall and reinstall data lover and reapply your desired settings.
Hello, I reinstalled it but I still have the same issue. It is set to update every 6 hours but the graph is still empty. GPS is working cause it shows a recent update for weather and location.
Which device do you have?
It's ok in the sim.
Did you uninstall prior the reinstall? If not do so.... if yes then not sure what else to recommend...
The pressure graph is fetched from the history it's not dependent on gps.
What do you mean by "Did you uninstall prior the reinstall?" exactly I don't follow. I uninstalled and reinstalled it just now.
I wanted to know whether you did a clean install or upgrade, but it sounds like you did a clean install...
I'm sorry but i dont know why the graph does not work on your watch.
Is it possible for me to roll back updates or can I only get the current one?
