- a readable time font
- sun events
- active statistics (heart rate / steps / stairs)
- YAHOO! weather & forecasts.
I have Venu 2, and am wondering if anyone else can see HR Line chart, if you set it for the bottom chart? It just shows a blank chart for me. If I choose e.g. Pressure line chart, it shows.
In Garmin Conenct Mobile (Android) you can select the apps that may send the messages to the watch.
Hi Peter, thank you for your comment. I still can't change settings on Forerunner 45. It keeps saying "we are exporting server connectivity issues. Try again later." Please help.
you don't need to ask the same question in 3 places. I've replied on the blog post :)
Thanks for this beautiful watchface.
Have you planned any localization? German would be nice for weather conditions (OpenWeatherMap supports german language in their API) and day and month of date?
Unfortunatly german Umlaute are not recognized in the cities of the weather conditions.
Please keep on the excellent work on this watchface :-)
localisation is something that i have started considering and likely will be tackled in one of the coming releases.
normally special characters should be removed and replaced by the character without diacritic (i have it on my todo to look why this does not function correctly)
Great that you are constantly trying to improve te WF! You have "internal temperature field" on your to-do list, and we hope that you will soon get time to improve WF with that option, as well
Hello I’ve got a bug when I select pressure in the bottom graph. The numbers (pressure value) are inverted. When I reed the graphe from the left to the right, high pressure value=low graph curve and low pressure value=high graph curve.
some fix for it?
thank you
there are several date formats in use and they depend on the length of the weather condition. it's possible to show always full length date by ticking the show top right field setting
