- a readable time font
- sun events
- active statistics (heart rate / steps / stairs)
- YAHOO! weather & forecasts.
								I have Venu 2, and am wondering if anyone else can see HR Line chart, if you set it for the bottom chart? It just shows a blank chart for me. If I choose e.g. Pressure line chart, it shows.
In Garmin Conenct Mobile (Android) you can select the apps that may send the messages to the watch.
Via app settings, for how to see forums.garmin.com/.../changing-your-app-settings-in-garmin-express-gcm-ciq-mobile-store
					Issues setting up watchface customizations on fenix 5x
Hello,
I am using a fenix 5x and have installed data lover as watchface.
When trying to adjust the setting of the watchface e.g. just switch off the "colon" and press save, I get the message that updates haven talen place, but they haven't!
The watchface on the fenix is still unchanged and as soon as I got back to the settings on garmin connect, they are back to the defaults!
I already de-installed and re-installed the watchface, but still the same issue exist.
Would be happy to get a hint how to solve this!
Thanks and Regards
Joerg
hi Joerg, it's an issue on ios.
See https://forums.garmin.com/developer/connect-iq/i/bug-reports/broken-settings-in-connect-4-22-for-ios (and while you're there also upvote the bug report)
					Hi Peter,
thks for the quick response!
I have upvoted the bug report.
Hope they can fix it soon!
Cheers
Joerg
Hi Peter,
I have a question about weather, as most of people do I read most of content here, but did't find any similar case - when I compare the data on my WF with the data on openweather.org for my location, the data is not the same...usually the data on openweather.org is correct. You can see the example in this pictures that I will attach.
So here you can see the data at 13:01 for my loacation, Split, HR = 29C
on this picture you can see the WF with sync at 13:02 showing 27C:
Here you can see that it shows the data for my location, Split:
And here you can see my app settings:
So, what is wrong, why WF is not showing actual data from openweathermap.org for my location?
thank you for your help,
daniel
P.S. my watch is Vivoactive 3, with 6.60 SW
the watchface uses the API that openweathermap exposes, it does not retrieve the data by "scraping" the content from the website
the picture is a little bit small for me to see but is the time of last fetch in white? (white=internet fetch succeeded, red=internet fetch failed)
Yes, it is white...if you need some additional info, or bigger pictures, just say so...:)
p.s. i removed the pic with key...sorry
the openweathermap api only mentions that it regularly updates the data, but not the frequence of the data update. I assume that the website uses a bit faster way of updating the data.
