Widget: TimeZonesWidget
TimeZonesWidget
Missing widget from F2.
Show:
- current watch time
- UTC and UNIX epoc
- 6 timezones available for You
This is first alpha version, please send questions, errors and propositions - by forum.
Versions:
0.0.1 - initial appstore version
0.0.2 - recalculate DST table for US&Canada
0.0.3 - add DST table for Australia and New Zeland
- add cities from Australia i New Zeland
- add menu 'other' with ZULU and @time
- add 12h/24h
0.0.4 - add testing support for 920xt
0.0.5 - support for vivo and epix
- add label editor
0.0.6 - add second page of timezones
- show centybits in @time
0.0.7 - new menu split - by continens (undone but more than less)
- many more cities
- new special "timezones" near @time - seconds from midnight (local and utc), minutes from midnight, fraction of a day
- repair New York dst settings on initial screen
0.0.8 - repair menu navigation, You can change timezones many times in one widget session and app don't crash
    Former Member over 10 years ago
    Data fields 4 style black & white:
    Hi .. I just installed the widget .. let say my current time is 12:00pm ... but in the widget it shows 12:00am ... how to fix that? thank you..
    Wait 1 hour? ;)
    Ok, I will check this. I live in 24h country and maybe I make a mistake.
    hey hey ... you are right ...after an hour the time in widget is correct now.
  • Hi, updated to the new version and every time I tried to change the setting it would lock up the watch and give the IQ screen with the"!". I eventually uninstalled. any thoughts.... I really like the widget
    Thank you for report :)
    I must add new property to the setting: "layout mode". And I think it is a problem:
    https://forums.garmin.com/showthread.php?230354-set-get-property-on-upgrade
    You try change 1 TZ, and layout to another one leave and back to widget or restart watch. You can remove settings file from watch filesystem folder: garmin/apps/data and look for file contains timezone names.
    I try lock up widget on my watch but I can't.
    I uploaded new version with a "12 am <> pm mistake"
    Hi you probably new this, but seemingly my timezones customisations did not get retained when my F3 battery went flat. Bit of a nuisance having to set them up again whenever the battery goes flat. Also Australia Pacific timezones is missing +8 Perth. I realise it is the same zome as HKG and SIN in Asia but would make some sense to add it in too. Great utilty BTW.
    Widget resets my watch face
    Hi, I downloaded the widget and can adjust the time zones without crashing the watch and the 4 zone display looks great. Unfortunately, it resets my watch face to the preloaded digital display each time I bring up the widget. :confused:
    Using it on a fenix 3.
    Thanks,
    Former Member over 9 years ago
    This looks good, but it not possible to select the time zones on the Epix. By holding in button 5 (UP) the select slot screen is displayed but then it is not possible to select the appropriate slot. The buttons simply go back to the Time Zone display screen.
    I really need this functionality and your widget looks good so I hope that you can fix it.
    Thanks,
    David
