Watchface: DigitStorm
Please post any problems and suggestions here.
Sorry that my English is ... google translate. :-)
  • Hello,
    Sorry for my question but ... in the app I do not see the new option to choose active calorie bars. Where is it? I have the FR 235 with the last version of the Digistorm (2.72).
    Thanks in advance.
  • Hi there,
    I'm also looking forward to this feature :) It doesn't seem to be available just yet.
  • lagm2k18, pieras123:
    Sorry this my mistake, now fixed false name in setting "Active calories in day".
    Gimli:
    Bars not working 1hz mode.
    I can not do this, it uses a lot of resources, and the watch face main idea is not to use a lot resources.
  • Thanks a lot! It is perfect now. Please keep it fast and battery saving. It's the best watch face for VA3.
  • This is my favorite VA3 watch face! The only request that I would like to see is the option to set some of the fields to "Off". For example, I want to move steps to the top field 1 and turn field 3 "Off" to make it a little more minimalist of an interface. Some fields let you set them to "Off", but field 3 does not. I would also like to disable the notifications icon. If I had those options, this would be the perfect watch face!
    Thanks!
    Rob
  • robp27:
    If I'm doing this, half the screen will empty.
    You can make a black background and number and will not see the fields.
  • robp27:
    Thanks for the text color tip!
    Former Member over 7 years ago
    Hello,
    I like this watch face a lot. I have a suggestion. Can you add the battery, and steps icons next to the display fields.
    Thanks
  • brs330:
    I tried to do this, but it looks awkward and reduces the visibility of the bars. Sorry.
  • Hello Gurjon
    I look at the evolution of your work and I think it is really at its peak.
    The bigger font is very good
    The themes should be pre-set ... for the white theme should have the white background with black letters.
    I have a little challenge to suggest you.
    On a normal watch there is an option so that every hour there is a "bip, bip"
    On a "Forerunner 935" there is a sound alarm. Would you be able to have an hourly chime?
    Looking forward to your answer ... thank you
