Watchface: DigitStorm
Please post any problems and suggestions here.
Sorry that my English is ... google translate. :-)
  • Brandon.ConnectIQ:
    Ok, Thanks!
    Gimli:
    Try turning to turn on field 2 (any parameter), may be it will work.
    Former Member over 7 years ago
    So I figured it out. The mile / kilometr setting must be set at the clock setting. It works now. The time of the next solar event does not work. Now shows -734: -33.
  • Wilda69:
    I think the problem is that you did not enter the coordinate in the settings or entered them incorrectly.
    Hello Jonas :-) Tonight at 0:01, the time of the solar event reappeared. Perhaps this is related to the end and the beginning of the new moon (1.2.2018). So another solar event works again. I know that is a lot of work and I keep my fingers moving. Thank you very much :-) Great work.
  • Gimli:
    Yes, it's both a reduction in memory and a design that is not logical. If in field 2 show steps,
    this will also mean that field 1 is enabled, which means that after > 9999 steps, the Field 2 will climb on top of field 1, and also is with field 5, field 6 ...
    I think that you can get used to the small inconvenience but have good visibility.
    Hello gurjon,
    thank you very much for this beautiful watch face. Perfect design and it doesn't slow down the watch.
    But still I have some requests, maybe you can realize one or two.
    I use date format "DD.MM", is it possible to add a dot after the month so it looks like this "DD.MM." (for example today: 02.02.)?
    The only thing I am missing from the watch face I used before is a moon phase icon. Is there any chance to add it to the watch face? Maybe placed to the notification field, visible when there are no unread messages.
    Thanks in advance!
    Best regards
    Draqqo
  • Draqqo:
    You can set the date format in the settings. The kind you ask is really there.
    Moon phases, it requires a lot of resources, so I not to doing in this watch face. Sorry.
    Thanks.
    Thanks for your reply.
    I think you misunderstood me. I know that the date format can be changed in the settings. I am using the format "31.12" right now. I ask, if it is possible to add a dot after the month so the display would be "31.12." with a second dot after month.
    Thank you!
  • Draqqo:
    Added this "31.12." format.
    Perfect!
    Thank you very much!
