Watchface: DigitStorm
Please post any problems and suggestions here.
Sorry that my English is ... google translate. :-)
    Former Member over 5 years ago
    Hi,
    There is an option to auto update location data for sunrise/sunset events.
    But it seems that it doesn't work, I have that option enabled and also I run GPS dependent applications, so I can see that GPS data is obtained successfully, but I don't see sunrise/sunset time in the fields.
    Is there a way to make it working?
    Thanks!
    ihor.
  • Hello. Cordinates is wrong- time for sun set and sun rise is wrong, and the field for cordinates is not possible to adjust. You fix.... :-)
    Former Member over 5 years ago in reply to Pingwald
    Hi,
    I understand that, when I manually set the coordinates it works.
    But I meant the "auto adjust coordinates" option, it seems giving me wrong values.
    Thanks.
  • Hello 3369340. My message was to the master of the watch face :) I have the same issue as You, and hope he can fix it.
    Battery getting chewed up by something,  cant work it out? Any tips
    Cheers
    Vanessa
  • It certainly would be nice to see a sensor temperature option in the custom fields dear gurjon .
    I have a 6x and your Digitstorm is my one n only favorite watchface ! Thank you sir .
    I love this watch face, the only one I  use. Good work Flag auCall me
  • I have terrible lag with my HR. It's in field one and I have the 1hz box checked. Please help!
  • I made a few comments re HR, because the developer isn't using real time 1Hz HR on page 1, he only activates 1Hz real time HR on page 2 so it's not draining power, most probably because he allows seconds on page 1.
    I've made numerous comments on this forum and contacted the developer but no response and he doesn't seem to be updating THIS GREAT and MY FAVOURITE watch-face.
    I actually use Bigfont Heart Rate 1Hz watch-face because it's clear and has HR in real time and big font.
    I feel similar to you, I require continuous seconds in FIELD 5 but require 1Hz HR in FIELD 3. Until I can use your watch face this way, I have to use another because I want continuous seconds and constantly updating HR. I had a heart attack in May'19.
  • Is anyone other than me having an issue with this watchface suddenly restarting the watch over and over?
