Let me first say, this is a watch I developed for me, and as of today, it's only been tested on a vivoactive. Changes to what is shown, may be considered.
A few requirements that I defined myself. It's SIMPLE! Not too much, and not too little, as it should be easy to read (for more details, you can swipe to the activity widget).
Top line - on the left the battery level in %. No graphics. On the left, characaters showing the state of stuff with the device, with lower case off, upper case on (I'm waiting for a standard for icons on a watchface, as you DO NOT want me to draw icons!). I'll add others as I can see them from Connect IQ, but for now, it works with BT status (on FW 2.60), "M" if you are in a move alert, and "V" if vibrate is on in the device.
Time - it's always hh:mm and works in 12/24hr mode, but no seconds. When not in low power mode (a few seconds at a time), the ":" changes to a "." and back, every second, It shows the data is current per second.
Date: I NEED DOW, Month and Day, otherwise I might be a month off when I talk to someone! :)
And Steps.. It's simple - current steps vs goal. It's orange if you are under goal, and green when you pass it, so a glace will tell you if you passed your goal.
If anyone is interested, I'll figure out how to publish it.
