Widget - Weather Radar Widget
Note: WUradar Widget is now known as Weather Radar Widget!
I got approval for a widget to display a Weather Radar image based on the device GPS coordinates.  Use the following link to download the widget.
https://apps.garmin.com/en-US/apps/9c692f27-57d6-4488-91ae-5dd846a4ad26
Sep 27, 2021 - Added Weather Radar App to the store
https://apps.garmin.com/en-US/apps/bddf48af-bbdb-425c-bc7f-34309e529a2e
The Weather Radar App is essentially version 4.33 of the widget released as a full device app.  This version allows for full screen images on all supported devices.  Enables animations on a few additional devices than supported by the widget.  Lastly, the radar image will auto update every 5 minutes and will not time out and return to the watch face.  Both the widget and the app share a common registration, so if you subscribe to either the widget or the app, you get access to unlock both versions.
App Setup:
Version 4.0 represents a major overhaul in the Weather Radar Widget.  It no longer requires any configuration and should work from initial download.  The radar data being used does cost each month, so this widget has switched to a trial/subscription model.  To start out every new device gets a 21 day free trial that is fully functional.  After the trial is over, you need to sign up for a nominal annual subscription.  After completing your subscription, go into the settings and and your email address used for from the PayPal transaction.  The next time the widget is run, the widget will remain unlocked for 1 year.  After which, you will need to renew again.
Follow these step in order to enter your email address into the settings.  https://ciq.sabeard.net/wrw4/registered.php
Using the widget:
This widget will show up in the widget loop on the device.  How you access that loop will depend on the device.
Button Watches - Press the up or down buttons on the watch until you see the Weather Radar Widget
Touchscreen Watches - Swipe up or down until you see the Weather Radar Widget
Edge devices with Buttons - Use up or down button until you see the Weather Radar Widget
Touchscreen Handheld and Edge devices - Swipe down from the top of the screen to show status page, then swipe right or left until you see the Weather Radar Widget
Acknowledgements:
I decided to write this widget because I recently upgraded my edge 810 to an edge 1000. After setting it up, I noticed the accuweather widget could tell me if it was expected to rain, but there was no way to view the radar map without pulling over to take out the phone. I keep my phone in the saddle bag while riding, so not really convenient. I was surprised that there was not already a radar app in the store. Last week I decided to download eclipse and the SDK plugin and try to write my own app. Armed with the ConnectIQ programming guide and SDK samples, PETERDECKER's tutorials and links to source code examples, and jim_m_58?s tutorials and ideas based on WU Weather Widget, I came up with WUradar. Thanks guys for the inspiration.
The original plan was to release this only for the edge family of devices, however after playing with the configurations I was able to determine fairly simple method to scale the images to work on all the watches also. While the edge devices are better suited for this type of widget due to the always on GPS, there is no harm in including the watches too.
Let the questions and feedback begin.
Starting with version 4.9 the following devices support radar animation:
D2 Charlie, D2 Delta Series, Decent MK1, Edge 520 Plus, Edge 530, Edge 820, Edge830, Edge 1000, Edge 1030, Edge Explorer, Fenix 5X, Fenix 5Plus Series, Fenix 6 Pro Series, FR245m, FR645m, FR945, GPSMap66/86, Captain Marvel, First Avenger, Darth Vader, Rey, Marq Series, Oregon 7xx, Rino 7xx, Vivoactive 3 Music, Vivoactive 4, Vivoactive 4s
Any device not listed does not have enough available memory to display more than a single image.
REQUESTED FEATURES:
Option to zoom map size +/- scale - implemented - Added the ability to change the default zoom level in settings in 1.4, changes on device in 2.4
Option to display rain speed and direction - Direction can now be determined when using animated images on supported devices with version 4.8.
Set color of position dot based on GPS status (Last, Poor, Good) - implemented in version 1.14
Ability to save location for future use - implemented in version 4.17 for watch devices
Ability to load radar current radar image first in animations - Updated in Version 4.33
Add on screen button to enable animations - Added in version 4.33 for Edge and touchscreen handheld devices.
Change Log
4.33 - Officially added support for new devices released in 2021. Animation now download current radar image before starting into the image rotation, this has been requested a few times, finally figured out how to do it efficiently. On touchscreen Edge and handheld devices added an on-screen button to enable/disable animations. Under the hood optimizations to be more efficient with memory.
4.32 - Added support for Venu 2 series
4.31 - Added animation support for Descent MK2
4.30 - Officially added support for Enduro and VenuSq/SqMusic
4.29 - Fixed out of memory crashes on VA3 and FR23x devices
4.28 - Added a credits page to the about screen to acknowledge the active map and radar source being used. Added option on watch devices to hide zoom label and radar source from the radar screen. Fixed crash on CIQ1.x devices when viewing about screen.
4.27 - Added support for fr745 and fixed expiration date on about page to match the timezone set on the server.
4.26 - Optimized memory to reduce crashed on low memory devices while increasing the the viewable size on the image. Removed support for personal developer keys as AerisWeather has chanced their renewal policy.
4.25 - Added support for the newest devices Edge 1030 plus, Marq Golfer, and Mercedes Venu.
4.24 - More memory optimizations to prevent out of memory crashes on low memory devices while trying to access the menu.
4.23 - Fixed an out of memory error on Vivoactive 3 and a menu initialization bug which caused a crash on certain devices.
4.22 - Fixed an out of memory error on the Vivoactive watches.
4.21- Fixed a bug which could sometimes cause the widget to crash on startup on newer devices.
4.20 - Bug Fix
4.19 - Added RainViewer as a second radar data source. This will dramatically increase radar coverage options for all users. To use RainViewer, open the menu then choose Select Radar Source to choose between AerisWeather and RainViewer. AerisWeather provides a higher definition radar image, but RainViewer provides more coverage.
4.18 - Added support for new devices.
4.17 - Fix issue causing black image download on Venu devices. New feature on watches to save and use a previous location. If using a saved location, you can manually refresh to your current position.
4.16 - Fix for another cause of crashes after saving the registration email with the ConnectIQ app.
4.15 - Fixed a bug causing a crash for users trying to save registration after the trial or registration had expired. Until now the work around has been to reinstall the widget and save the registration email address prior to running the widget.
4.14 - Fixed an issue causing error -300 message on F3 devices. Fixed an issue causing some devices to crash after entering registration email in settings.
4.13 - Implemented fix for some devices which would always report phone not connected when it really was. i.e. Edge Explorer 1000.
4.11 - Fixed a bug causing radar images to be displayed in the reverse order.
4.9 - Fixed crash on VAHR and Epix.  Added support for all devices with enough memory to show radar loop.
4.8 - Added option on Map enabled devices to animate image loop. When enabled, the widget will show image loop of the past 30 minutes, 15 minutes, and current. If your device is supported, the option to "Enable animation" will appear in the menu. Supported devices for Animation include Edge devices (except Edge520), F5X, F5plus series, F6pro series, Marq Series, FR945. Still investigating how to support FR645m, FR245m, VA3M, VA4S, and VA4. All other devices I am at the memory limits for widgets and will not get support for animation.
4.7 - fixed more glance view implementation issues on the F6 and Marq
4.5 - Fixed a crash in Widget Glances on F6 and Marq devices. Customized Widget from system defaults.
4.4 - Released to fix bug in Garmin SDK affecting Fenix 6 devices.
4.3 - Added support for Fenix 6 Series, Venu, and Vivoactive 4 Series, fixed some bugs with entering Registration email in settings, and added vibration and background light notification on watch devices. Now you get alerted once the image has downloaded.
4.2 - Fixed some more crashes.
4.1 - Fixed some bugs causing crashes on some devices
4.0 - Major overhaul to the app.  Added registration checking and moved other options from settings to on device menu.  Added about screen to show version and registration status.
3.10 - Added support for new Forerunner and Edge devices.
3.9 - Decreased memory usage on high memory devices, i.e. F5+ series. Hopefully this will help improve image download time.
3.8 - Added support for MARQ and other new devices.
3.7 - Removed support for Weather Underground as the service finally shutdown all support for API keys. Aeris Weather is the only option now!
3.6 - Added support for GPSMAP® 66s / 66st
3.5 - Added support for the new D2 Delta series. Changed Global Satellite to use dark background and added option for color IR satellite view.
3.4 - Added support for Edge Explore, Set Aeris Weather as the default for new installs, Developed new method to use last known GPS position on watch devices based on Garmin fixing in new device FW that I was exploiting.
3.3 - Added support for new devices, VA3M, and F5 plus series.
3.2 - Improved key checking to ensure the key entered is the correct length. Fixed broken error reporting, app will once again report if the download failed, instead of hanging on "retrieving image". Enter key will now open menu on watch devices.
3.1 - Added zoom buttons to touchscreen handheld and Edge devices. Adjusted zoom level designation to match buttons, L5 is most zoomed in, L1 is most zoomed out.
3.0 - Complete rewrite of the code structure. Streamlined image retrieval and display update processes.
    Former Member over 6 years ago in reply to Former Member
    Same.
  • I have been getting a few other issues with Fenix 3 devices.  Can you tell me a few things.  Has the app ever worked for you?  if so, when did it stop working?  What version of GCM do you have installed and what phone type, iOS v Android?
    I don’t setting app because watch show  API key missing
  • Set up the app on a Edge 1000. Set up my account with Aeris and got my secret key and application ID and entered them into Garmin connect mobile. When I launch the app on my 1000 it loads and says waiting on postion, GPS good,retrieving inage and gives me error code 0. Tried to install and remove it 2 times and my account with Aeris is good until mid July. Any idea's of what I'm doing wrong?
  • Most often error code 0 comes up when there is either an error in the code entry, or the developer subscription has expired.  Since you said it is good until July, I suspect it is the first.  Once you login to your Aeris Weather account, look for the menu choice for map builder.  Make sure it can make a map for your area.  If it can, you can use the URL at the bottom to grab your appid and secret key.  In the URL you are looking for two random strings separated by a "_".  The first string copy into the app id.  The second string copy into the secret key.  Be care not to get to many characters when copying he strings.
    Former Member over 5 years ago
    On my Forerunner 245, I’ve installed Aeris weather radar app and the widget reads Weather Radar 3.13, Retrieving Image, GPS Last and it won’t show the radar map. Any thoughts?
  • Sorry I have not been on the forum for a while and it appears that my subscription is not working.  Are you still seeing problems with this issue?  Sorry I have not been on the forum for a while and it appears that my subscription is not working.   fixed a couple bugs which were causing other errors.  If you are sitting on the retrieving image screen, the. I suspect that there is something wrong with the way you entered the keys.  It would appear that since you don't get an error message, then the server is never responding to the download request.
  • So after a long absence from this, I decided to try to install this again and make it work.  It doesn't.
    Garmin 1030, running latest version.  The issue is with AerisWeather.  When I try to renew the 2 month developer setting, it just keeps telling me that the package doesn't exist, and INSISTS I pay $45 a month for this.
    Uninstalling, my 1 star stands for the same reason it did before.  It relies on that 3rd party to work.
    [deleted]
  • I have received similar feedback from a few other users.  If you don't mind I would like some additional feedback.  I have been looking at an option which would eliminate the need for the end user to manage and renew the keys from Aeris Weather however as you point out that would not be free.  I am thinking about offering a 2-3 week full functional trial, then requiring a small annual fee (<$5/year) to cover the costs of the radar source after the trial.  This should provide a better initial use experience with much less needed hassle to keep the app working.
    Let me know your thoughts.
