Watchface: Simplicity
Simplicity
Simplicity: Roman v2.5
Simplicity: Light v1.5
Simplicity: Dark v1.5
Clean and simple watchfaces. No disturbing elements, just the time, and in the case of 'Simplicity: Roman', the current date. Second hand is visible on gesture.
NEW:
Simplicity now supports user settings for watches supporting ConnectIQ 1.2 or higher.
Available settings:
  • Digits on/off (Simplicity: Dark/Light)
  • 1 minute markers on/off (Simplicity: Roman)
  • 5 minute markers on/off
  • Battery Status on gesture on/off
  • Bluetooth status on/off
  • Steps on/off
  • Notifications on/off
  • Red or white 5 minute markers (Simplicity: Roman)
Steps and notification icons made by Freepik from www.flaticon.com.
How to change App Settings
Updates
Simplicity: Roman v2.5 (October 16, 2016):
  • Added support for steps and notifications
  • Larger 'date' font on Fenix series
Simplicity: Roman v2.4.x (September 18, 2016):
  • Memory optimizations
  • Support for all round Forerunner and Fenix series watches
  • Improved performance when minute markers are on
  • Removed version number on gesture
Simplicity: Dark/Light v1.5 (November 17, 2015):
  • Support for D2 Bravo, Forerunner 230, Forerunner 235 and Forerunner 630
  • Added support for user settings
Simplicity: Roman v2.3 (November 16, 2015):
  • Fixed color settings for markers
  • Displays version number on gesture
Simplicity: Roman v2.1 (November 10, 2015):
  • Added support for the Forerunner 230, Forerunner 235 and Forerunner 630
Simplicity: Roman v2.0 (November 10, 2015):
Simplicity: Roman v1.5 (June 25, 2015):
  • Added support for D2 Bravo
Simplicity: Roman v1.4 (April 17, 2015):
  • Battery icon always visible when battery below 30%
  • Removed battery icon on gesture
  • Small tweaks to hour and minute hands
  • Various code optimizations
Simplicity: Roman v1.3 (April 2, 2015):
  • Added battery icon on gesture or when battery below 30%
  • Made hour and minute hands wider and changed color to white to improve visibility
Simplicity: Roman v1.2 (March 25, 2015):
  • Made hour and minute hands slightly thinner
Simplicity: Roman v1.1 (March 20, 2015):
  • Changed color of second hand
  • Added 5-minute markers
  • One of the most elegants watchfaces! For my job, should be nice to have a third hand showing gmt time.
    Thanks for your job.
    Former Member over 9 years ago
    131
    Version 1.5 of 'Simplicity: Roman' released, added support for the D2 Bravo:
    I like this ...
    Nice, very good. VERY GOOD.
    I do not need the second hand at all. Just a clean face.
    If you, for some reasson, added it to the watch ( every second ) please make it an option.
    Question : How do I make the the face change from just "lines each 5 minutes" ( the first 2 secreens on the left) to "lines each minute" ( the 2 first on the right) ?
    As soon as Garmin provides support for user settings I will add the possibility to disable seconds, add minute markers and so on. I will possibly add some color options as well. I use red five minute markers on my own grey Fenix, and that looks really good on that watch. On the D2 I think the face would look good without any markers at all.
    But as I said initially, this is not currently possible due to lack of support in the API.
    As for the minute markers on the images on the right, they are part of the physical bezel on the watch itself.
    Minute Markers
    I downloaded the latest version. I can see the roman numerals along with the 5 minute markers. What is not visible are the minute markers. Can you please advise. Thank you.
    The watchface shows 5 minute markers only. Any one minute markers in the screenshots are physical markers on the watches themselves.
    NEW:
    Simplicity: Roman now supports user settings for fenix 3 running firmware version 5.0 or higher :)
    Available settings:
    • Battery Status on Gesture on/off
    • Bluetooth Off Warning on/off
    I recommend red markers on the grey fenix 3 and white on the silver fenix 3. Default is no markers, simply because that looks best on the D2 Bravo, and user settings are not supported on that watch yet.
    User settings are edited either in Garmin Express or Garmin Connect Mobile.
    In Garmin Connect Mobile go to Devices ->fenix 3 -> Connect IQ Apps -> Watch Faces -> Simplicity Roman.
    Then select Settings, and select your values. Finally press Done.
    Changes should be visible on the watch after a few seconds.
    Simplicity: Roman v2.1:
    Added support for the Forerunner series :)
    Yes, I'll add 1-minute markers in the next update.
    I didn't think they were necessary on the fenix and D2, but I can see they may be useful on the Forerunners.
