Sports+ is a Fitness Tracking Application for all the other Sport activities including native support for Basketball, Soccer, Baseball, Softball, Football, Hunting & Fishing. This application keeps the score and saves the score to Connect.
Sport type is configurable: Soccer (Default), Tennis, Basketball, Football, Hunting, Fishing and Custom (Baseball, Softball, Volleyball, etc. ).
Full Version : Full Version Click HERE for information how to get the FULL Version
How to Use (Please Read):
1.) Watch must be worn on your wrist!
2.) If you don't have a Chest HRM, Footpod or Running Dynamics Pod, your Watch hand MUST be MOVING.
4.) Chest HRM (3, red or blue) will give improved results.
5.) Foot Strike Sensor with HRM gives the improved results, too.
6.) To enter score menu use the "LAP" button,
-Lap press 1, Edit Team A. Use Up/Down to edit*
-Lap press 2, Edit Team B. Use Up/Down to edit*
-Lap press 3, Return to Data Screen.
*touchscreen swipe up/down (it works in the simulator){if it does not work, let me know}.
Requirements:
-IQ 1.3 or higher
-Optional: Chest HRM (3, red or blue), Foot Strike Sensor or Running Dynamics Pod (best accuracy)
Known Deficiencies:
-(Indoor Only) 'Main' Distance field and Garmin's Main Speed Graph are not reporting in connect.garmin.com or connect app
-Displaying Scoring field in Connect this is a Connect bug - https://forums.garmin.com/showthread.php?364535-Known-Issues-Thread
- I will work on this to get a workaround.
Displayed watch data
-Speed, Distance, RPM, Calories, Heart Rate, Average Heart Rate, Elapsed Timer, Time of Day
-Heart Rate is completely configurable and color coded.
-Configure Heart rate zones in Garmin Connect or Garmin Express using the generic zones
-Battery (Green Horizontal Line )meter uses the entire screen for reliability and acts as a divide to help focus one the upper fields.
-Battery color range: RED less than 15%, Orange 16%-35%, Green greater than 36%
-Fields are auto-adjust for all data ranges for maximum readability through out your entire activity.
-inActivity configuration adjustment. Use phone Connect app to change during activity
-BlueTooth Connectivity as a simple letter "B".
-Main Page Fields:
--TOP:HR (color, % and BPM),
--Second Line: Speed, Distance, Battery,
--Third Line: Average spd, Bluetooth, Elapsed Time
--Bottom: Calories, Time of Day, Average HR
-Second Page Fields displays three fields of data:
-- choose any 3 (Speed, Distance, Elapsed Time, Calories, Energy Expenditure,
Heart Rate(color), Avg HeartRate(color),steps, average step,, floors, cadence, Average cadence, temperature, and Training Effect).
Value of (-1) means selected data is not support in your watch.
Display Abbreviations:
B = connected to phone with connect app running
stp= cadence movement detected
hr:xxx = Heart Rate monitor sensor detected with current HR
tmp:xxx = temperature sensor detected with current Temp
Found Bugs or Negative Comments
-Don't leave negative comments for bugs. Email directly or post in forums.garmin.com
All my Apps
https://apps.garmin.com/en-US/developer/4ca4351d-f24c-40e0-bc3e-b187972a7526/apps
