Data Field: Surf Tracker
[FONT=Arial Black]Surf Tracker[/FONT]
Version 1.20
https://apps.garmin.com/en-US/apps/ded87d46-5477-4ca7-a247-847b896393e0
Track your surfing sessions in real time! This data field estimates the number of waves ridden using a speed and time threshold to mark the start and end of a wave ride.
Info shown (from left to right):
  • your total number of waves ridden and the total wave ride time (min:sec)
  • for your latest wave ride: wave ride time (seconds), maximum speed during the wave ride (km/hr or mph) and the distance covered (meters or yards)
  • the numbers in red show the maximum values for the wave ride time, speed and distance during the activity
  • For square watches, the bottom line shows the time of day and elapsed time of the activity. For round watches and the Vivo HR, the top line shows the time of day and the bottom line shows the elapsed time.
Notes:
1) This data field must be used in a 1-field data screen and should be set up before starting the activity. I use an Activity > Other > Paddle, but any activity with GPS ON should work. Open water swim will work but the GPS tracks are noisier since the sampling rate is lower, but it may be the better option for surfing when your arm is in and out of the water. Some activities smooth the speed data more than others and will give less accurate results (eg. a walking activity will not work as well as paddling or cycling). Vivoactive users try the Cycling activity, the Run activity will smooth the speed values to much to even out the Pace and this won't work well with the wave detection.
2) The summary stats and a speed plot are saved to Garmin Connect once the Activity is ended and saved:
3) This has been tested many times with standup paddle surfing. It has taken a while to get the thresholds working accurately. The detection thresholds can be changed using the Garmin Connect Mobile app (see https://forums.garmin.com/showthread.php?332843-How-to-App-Settings for help):
There are four settings to mark a wave ride based on speed, time and distance.
An event starts when the speed is >= 9 kph, it must last at least 6 seconds (above 9kph) and have a max speed of at least 13 kph to be counted. The event ends when it falls below 9kph. The min distance is set to 0m, but this can be changed to avoid false detections. These thresholds work well for standup paddle surfing, but try changing them and post your results. It should work for: standup paddle surfing, surfing, kayak surf, surf ski and maybe standup paddle downwinding.
Threshold ranges and defaults:
1) Start/stop threshold: default 9kph, range 5-50 kph
2) Time threshold: default 6s, range 2-60s
3) Max speed in event has to be >= 13kph, range 0-50kph
4) Min distance: default 0m (disabled), range 0-1000m
Typical values:
Standup paddle surfing: general setting for all waves
9kph, 6s, 13kph, 0m
Standup paddle downwinding (Hood River)
10kph, 10s, 12kph, 20m
4) The stats from each wave ride can be saved to a text file using the instructions at the bottom of the page (advanced users only, unsupported).
----------------- Planned Updates------------------
1) none hopefully
----------------- Version History ------------------
0.2 datafield now updates even when not visible.
0.3 added min distance to threshold test (now min 9km/hr for 5s and 15 m) to avoid paddling out/false wave counts, especially for SUP (eventually these values will be user selectable).
0.4 more tweaks after on-water tests (now min 9km/hr for 6sec), 19 waves and only 2 false readings and that was when I was chucked over the falls...
0.5 changed totdist and elapsed time to use the last good point of the event, instead of first one below the threshold, since when falling in it might take a while to get gps fix again and this will add to the waveride time. This should only decrease the wave ride time. The threshold test is now: >= 9km/hr for >= 6 sec and maxspeed >= 13 km/hr, redesign screen, add total wave ride time in min:sec
0.6 add fenix support.
0.7 bug fixed- crash when data field is in view and GPS just becomes active
0.8 D2Bravo, Epix and Vivoactive (separate app) support, compile using SDK 1.1.4. Latest numbers are green during an event (shows green if above speed threshold, even if below time threshold).
v0.9 new SDK 1.2.1, support for fr230/fr235
v0.95 new SDK, 2.1.3, support for Vivoactive HR
v1.0 added GCM settings for thresholds, changed distance calculation (should be shorter and more accurate), added 1 field Vivoactive support (got rid of the separate version)
v1.20 Garmin Connect summary stats and wave speed plot output
_________
** Advanced user only+unsupported method to save each wave ride to a text file on your device:
Place a *.TXT file in the /GARMIN/APPS/LOGS folder on your device, where * is the name of the .PRG file in the /GARMIN/APPS folder. Look for a file that is ~12 kilobytes. On my device it is 69SI5820.PRG, so I would create an empty file in /GARMIN/APPS/LOGS/69SI5820.TXT
To find out the filename, uninstall Surf Tracker, make a note of the *.PRG files in the /GARMIN/APPS folder, install Surf Tracker then note which PRG file is new.
Sample output format:
Wave# TimeofDay WaveRideTime(sec) WaveRideMaxSpeed(kph) WaveRideDistance(m)
1 07:26 20 28.8 113.4
2 07:28 13 27.6 76.8
3 07:33 21 30.2 122.2
Copy the file to your computer after a few sessions. I copy and paste the details into the notes section of the activity on Garmin Connect. The file will be appended to until it gets too big (10KB), then it will be overwritten. I had 3 days of sessions saved and it was only 1.8KB.
  • Hi: sorry the instinct doesn't have connect IQ support, so it will not work:
    "– Doesn’t have Connect IQ support: No data fields, apps, or widgets"
    www.dcrainmaker.com/.../garmin-instinct-gps-watch-in-depth-review.html
  • I have noticed they added new fields to the Surfing activity in Garmin Connect
    Total Waves
    Longest Wave
    Max Speed
    Surf Time
    Any chance Surf Tracker2 could set these fields in the Garmin Connect activity ?
    Thanks!!
  • I have all the setting s as per your comments. I have version 3.01 on my Vivioactive 4S.
    I watch falsely records waves even when I paddle out?! And sometimes doesn’t even record my waves taken at all?!
    Please help!
    Thanks
  • I have similar issues. The best I get out of it is the GPS track at the end of my surf. The app needs significant reworking in my view. I have given up with looking at my wave count it is never accurate. And yes a get a few waves paddling out, too!
    Hi I use from several years your super data field. However now with
    Forerunner 735XT
    Software: 9.80.0.0
    and the last Surf Tracker version
    I'm not able yet to collect data about
    Connect IQ
    Total Wave Count
    # of Lefts
    # of Rights
    Total Wave Ride Time
    Total Wave Ride Distance
    Longest Wave Ride Time
    Longest Wave Ride Distance
    but wave Ride Time and speed graph are saved and visible on Garmin connect.
    I'm not able to understand wath's happen...
    Can you help me ??!
    hey guys been finding lately that Im not tracking/counting waves very accurately any more, when I first down loaded it was spot on with wave count etc. Is there anything in settings I should be looking to change?
    Thanks
    Thanks
    Ho problemi di installazione della app su un forerunner 645 music
  • I had to reboot my Forerunner 735xt. After that, I've installed other activites to work with Surf Tracker. First tried SUP then OTHER. Neither showed the Surf Tracker v.2 Data Field. Mind you that I've indeed transfered the Surf Transfer from Garmin Connect to the watch. It showed so on the display ("Transfer Concluded"). Am I doing something wrong? I took exactly the same steps from my first installation 3 years ago and it isn't working. Please help me.
  • Hi there. I had to reboot my Forerunner 735xt. After that I've added another activity; firstly SUP, then deleted and instaled Others. Then installed the Surf Tracker v.2 on the Garmin Connect, then on the watch. However I cannot change the data fields to include Surf Tracker's, nor it shows on the watch. What gives?
