YABF - Yet Another Bike Field
YABF is my brandnew bikefield (Yet Another Bike Field). The current beta version shall help to review the layout on the real watch and to discuss the features.
Almost all functionalites are in the data field now. Please report bugs here.
The outer circle represents speed. Max speed and average speed are also marked there with triangles. If your speed is greater than 30 km/h or mi/h add 30 to the speedometer scala. For example 10 represents 40.
The inner circles wil be filled up with (note that the position of the circles can be set by user):
- Cadence - it shows the current, max and average cadence by pointing to colored cadence zones (user can set three cadence zones)
- Clock and in digits within the circle: calories burned - the color of the clock can be adjusted by user
- Direction and direction to start, battery level indicator as ring and rings which tells the user something about the distance to start (e. g. if 1 km is set in the YABF settings, a full green ring means that the user is 1 km away from start, a full yellow ring means that the user is 2 km away and a full red ring means that the user is more than 3 km away from his starting point)
- Heart rate - show the current, max and average heart rate by pointing to colored heart rate zones (heart rate zones are grabbed from your profile)
The digits in the middle part shows distance and current timer time.
You can download it here for FR935, F5 and F5X: https://apps.garmin.com/en-US/apps/67811264-44c9-41b7-95ac-775c2255f891#0
