Chrono Style Watchface
Hello,
this is my first contribution to this forum and my first watchface.
It's called chrono style watchface and you can find it in the store.
https://apps.garmin.com/de-DE/apps/66ee453a-cd28-4620-ac1d-e6e7e15689cc
If you want to support me: https://www.paypal.me/Dirk72
Features:
- Chrono style look
- Activity gauge: Steps, distance, daily goal, history steps, calories
- Altitude gauge: Hand displays 100m or feet, triangle displays 1000m or feet
- Battery gauge: Hand displays 10%, triangle displays 100%
- Sunset/Sunrise gauge: Displays the next 2 sun events, solar altitude, time until next sun Event
- Sensor history gauge: history field, hand displays recent value, triangles display min and max values in history, scale auto adjusts (Fenix 5 derivates only, HR works with F3HR and supported Forerunner devices)
- Moon phase gauge: moonage, days before and after fullmoon, arc also shows moon phase
- Small moon phase gauge
- Digital watch with 2. time
- 2 configurable digital fields with date, clock and heart rate (on supported devices)
- Activity level showing on margin or micro bar
- Notifications
- 2 hand styles
- Micro battery Icon
- Cycle through activity info while active
- Bluetooth Icon
- Blackout Edition
- a lot of possibilities to configure colours and functions of the watchface
I have several reasons why I post here:
1. A lot of people had good suggestions and helped me to get the watchface to its current state. Thank you for that. It's a lot easier to discuss suggestions here than via email or the connect iq store.
2. Since I "only" own a Fenix 3, I can't test every feature of my watchface myself and so I need a platform for people, who want to help and give feedback. Um well yes, I want you as beta testers :rolleyes:
So here we are. I am awaiting your wishes, your feedback and your comments.
Cheers
  • In fact, with the backlight setting for gesture set "on", it works fine.
    Thanks, I hope garmin will fix this
    Hi,
    thanks for the confirmation!
    Digital time one minute late on hands time on Fenix 5
    Hi Dirk,
    Thank you very much for this very good watch face.
    My bug report is the one mentioned in the title. I have noticed that in some situations, both times (digital and analog) are sync. but can't replicate it.
    I would also suggest some improvements: the ability to define different colors for the dial hands and graph (for clean reading of the right dial).
    I wanted to attach a picture to illustrate this post but it seems to fail. I can send it to you per regular mail if you want.
    Thank you in advance and have a nice day.
    Leo
    PS: I can also help for beta testing on Fenix 5.
  • Hi Dirk,
    Leo
    Hi,
    thanks for the offer, I will be glad to come back to you, when I need some testing. This may be necessary when I implement 1 Hz mode or weather functionality. Both features are on my future to do list, but at the moment I am trying to figure it out.
    For your bug, I think I fixed it.
    In one of the next updates I will also add the possibility to switch the color of the graph.
    I have one further question, the watchfaces, which support 64 colors, how do they let the user choose the color? Is there a list of 64 colors? Would be nice if somebody could answer me that question, because on my Fenix 3 I can't test it.
    Cheers
    Line Watchface
    Hi,
    Cheers
    Hi, so far the only watchface I've seen dealing with 64 colors is "Line" which allows to choose among a complete list of colors (with funny names such as "Hollywood sunset orange" or "Lime green", etc...)
    Wow, it's working perfectly ... I haven't even realized that the version was updated ... I look at my watch and seconds is working, I've counted 10 sec thinking it wil stop and it was still going on ... therefore I think it is set automatically on 1 Hz mode ... the only thing I had to disable was the cycle through info that was always on and a bit disturbing ...
    I forgot to say, I am on fenix 5s
  • Hi,
    did I understand you correct, the cycle through info is working 24/7 if you don't switch it off?
    Cheers
    I have to reconfigure setting each time I upgraded to newer version. Is that normal?
    Idea for 64 colors management?
    I agree with you that adding 64 colors option every field can drive you crazy.
    Would it be possible to give RGB levels options in every field? Red level from 0 to 3, Blue level from 0 to 3, Green level from 0 to 3?
    Probably a bit more complicated than today, but less than dealing with 64 different colors...
    I hope that helps.
    Again: you're doing great.
    In the latest version (v1.38), the notification count in watch face shows "0/zero", but watch actually receive several notifications from my smartphone. Does anyone else have the same issue?
  • I am currently looking at it. I haven't changed the code for the notification count in the last updates and in the simulator it works. At the moment I am a bit clueless. Does it work on other watchfaces? And just to make sure, you switched on notifications in settings?
