Watchface: Black & White
Hello all,
here is my 2nd attempt...
Simple & easy readable WF with only 2 colors and some data fields options. [for fenix 3 & 5 and vivoactive HR]
You can download it directly here:
https://apps.garmin.com/sk-SK/apps/9fb16706-e878-4dd1-a9d6-6c9283215e9d
Features included:
  • Time & Date
  • Battery gauge
  • Phone connection indicator
  • Notifications indicator
  • Data fiels: steps, goal, distance, sunset & sunrise, calories
  • Time format 12/24 (set according to watch settings)
  • Distance mile/km (set according to watch settings)
  • Possible to choose bigger font size for data fields
  • Supported semi-round devices (displays) - note! you can have only 5 data fields enabled
  • 6th data field can be switched OFF
  • Show/hide battery status
Premium features:
  • HR
  • Altitude
  • Battery status in %
  • Notification count
  • 2nd time
  • 5th data field ON/OFF
If you will have any issues, proposals, ideas please contact me directly or here in forum and
I will try to help you first before you leave negative comment or lower rating for watchface.
Hope, you will like it... if any idea for improving, just reply!
  • Do you like simplicity, reversibility or inversion? Me yes ;-) and this watch face was built for you too.
    You can find standard data, configurable and PREMIUM data fields.
    If you will have any issues please contact me directly and I will try to help you first before you leave negative comment or lower rating.
    Watchface was tested in simulator without problems also on Vivoactive HR & Fenix 5 - if you have problems you should try: check if you have free space, reinstall WF, reboot watches.. contact Garmin support ;-)
    Try normal version before you ask for PREMIUM DATA UNLOCK:
    Premium additional data - Heart rate, Altitude, Battery & Notification count jus
    IMPORTANT COMPATIBILITY NOTE:
    -Fenix 5 watches - in watchface settings don't forget to ENABLE F5 compatibility checkbox
    -Forerunner watches - you are able to display 5 DATA FIELDS ONLY! 6th data field needs to be DISABLED! (to show correct layout)
    ----/ FEATURES /----
    -time & date (12/24h), battery icon, bluetooth connection icon, notification status icon
    Configurable fields:
    -steps, distance, calories, goal %, sunrise, sunset
    PREMIUM - Heart rate, Altitude, Battery status, Notification count, Time 2 (other time zone), 5th data field ON/OFF
    Settings:
    -Fenix 5 compatibility enable - for correct layout
    -Bigger fonts
    -Time format - adjust time format according to watch setting (12h/24h)
    -Battery status - ON/OFF battery icon
    ----/ GUIDE /----
    You can change settings directly in Garmin Connect mobile app for iOS and Android.
    Menu: Devices / Yor device / Application Connect IQ / Watch Faces / Black&White
  • Nice work - but problem with sunrise/sunset and daylight savings time
    Nice work; visually very appealing :-)
    But it seems sunrise and sunset times don't account for daylight saving time and thus are currently one hour early for me.
    Additionally I would appreciate an indicator icon for pending alarms.
  • Nice work; visually very appealing :-)
    Hello, thanks for feedback.
    Sunset / Sunrise algorithm is ok to show correct Sunrise/Sunset on your watch you need to update your GPS location.
    For example you need to start activity with GPS - running, wait for GPS and you can discard it. It should work.
  • its not appearing in the IQ side of my forerunner 235
    After choosing the watchface and syncronizing with my FR235 I can not select it in the menue of my watch.
    Also other watch faces are not visible any more?!
    I am not sure if its your app or the watch itself which is not compartible?
    Thanks for your help!
    Thomas
  • After choosing the watchface and syncronizing with my FR235 I can not select it in the menue of my watch.
    Thomas
    hello, I dont know what could be the problem, maybe not enough space? try to restart or uninstall something.
    Hope it will works.
