App: StairMaster +
How To, Comments and Bugs Thread for StairMaster+ Application
Link to StairMaster+
Full Version : Full Version Click HERE for information how to get the FULL Version
How to Use (Please Read):
1.) Watch must be worn on your wrist!
2.) If you don't have a Chest HRM, Footpod or Running Dynamics Pod, your Watch hand MUST be MOVING on indoor equipment.
-- i.e. your hand and watch must move or the app will not work.
4.) Adjust Steps/Floors with phone Connect App to match indoor equipment typical value is 17 steps (8inch/22cm per step) .
--Configure in watch, use menu button, while in activity. (VAHR long press screen)
--Configure in connect app or Garmin express https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
5.) Chest HRM (3, red or blue) will give improved results.
6.) Foot Strike Sensor with HRM gives the best results.
Requirements:
- IQ 1.3 or higher
-Optional(best accuracy): Chest HRM (3, red or blue), Foot Strike Sensor or Running Dynamics Pod
Known Deficiencies:
-(Indoor Only))(Garmin Bug) 'Main' Distance field and Garmin's Main Speed Graph are not reporting in connect.garmin.com or connect app
-Workaround: Both Floors and Steps/Minute are shown as an IQ data field or as an IQ graph.
Custom graphs: Steps, Floors, & Momentary Energy Expenditure
Configuration items:
-Steps per Floor: default is 17 and matches the Stair master
-Indoor/Outdoor mode: no check GPS off, Check GPS on.
Second Screen
Top, Bottom Left and Right selections 14 selections to choose.
Displayed watch data
-Steps, Floors, AvgSteps, Calories, Heart Rate, Average Heart Rate, Elapsed Timer, Time of Day
-Heart Rate is completely configurable and color coded.
-Configure Heart rate zones in Garmin Connect or Garmin Express using the generic zones
-Battery (Green Horizontal Line )meter uses the entire screen for reliability and acts as a divide to help focus one the upper fields.
-Battery color range: RED less than 15%, Orange 16%-35%, Green greater than 36%
-Fields are auto-adjust for all data ranges for maximum readability through out your entire activity.
-inActivity configuration adjustment. Use phone Connect app to change during activity
-BlueTooth Connectivity as a simple letter "B".
-Main Page Fields:
--TOP:HR (color, % and BPM),
--Second Line: Steps, Floors, Battery,
--Third Line: Average Steps, Bluetooth, Elapsed Time
--Bottom: Calories, Time of Day, Average HR
-Second Page Fields displays three fields of data:
-- choose any 3 (Steps, Floors, Floors/Min, Floors_IQ(iq2.2.x & GPS), Elapsed Time, Calories, Energy Expenditure, HR(color), AHR(color), RPM, Average RPM, temperature, Training Effect, Activity Total Steps, Total Ascent (GPS)).
Value of (-1) means selected data is not support in your watch.
Display Abbreviations:
B = connected to phone with connect app running
stps:xxx Current Steps in spm
hr:xxx = Heart Rate monitor sensor detected with current HR
tmp:xxx = temperature sensor detected with current Temp
Results with footpod and HRM-Tri
Using v0.1 and was 95% accurate using Tri HRM and footpod.
Using v0.1, 99.9% accurate on Stair Master Brand using 17 steps/floor value
All my Apps
https://apps.garmin.com/en-US/developer/4ca4351d-f24c-40e0-bc3e-b187972a7526/apps
