Watch App : HRV
HRV app. Discussion, report bugs, suggested features, etc...
HRV
Get the app.
Graphing.
The design currently only saves to 1 location per day. The timestamp is taken when the test starts, so autostart will take the timestamp at the scheduled time. This means that any saved test will overwrite any previous test of that same day. A day is calculated from the local timezone, so travelling won't disrupt the storage so long as you have updated the timezone before starting the test. The averages are a 30 day mean average.
Description & Explanation
Wouldn't that be nice. Will happen, but might take a while.
This page could be useful.
Notes
- Your device must have firmware that supports Connect IQ Apps.
- You can save the results by creating a log file. To do this you must work out which name has been applied to the HRV app file. The apps are in the /GARMIN/APPS folder. It will be a name something like A6227C9B.PRG. You then create a log file with the same name, e.g /GARMIN/APPS/LOGS/A6227C9B.TXT. Each reading you save will output a result formatted as ISO8601 date & time, hrv, avg pulse, 30 day hrv avg, 30 day pulse avg.
    This app is just I was looking for. Thanks for this app and allow export the test results to a log/csv file, this is very interesting and useful. I use this app regularly.
    The app works fine with fenix 3 FW 7.50 / CIQ SDK 1.3.0.
    Hello,
    i wont ask again: There is a new Version of the Vivoactiv HR and a new Version Connect IQ - is it now posible to add the Vivoactiv HR to this great HRV App?
    Please :)
    Thx
    Hey guys, this might help you answer whether or not you can get the HRV app for a new device that hasn't been "made compatible" yet...
    I was able to take the HRV app .PRG file from the APPS folder of a Fenix3 (round face) and drop it in the same folder on a 735XT and get it to work without a hitch... hope this helps - at least until an app is specifically made available for 735XT (and others)!
    There is a new version 1.1.6-upd2 from 30th august 2016, what are the news of this version?
    How can I look/see HRV in the Garmin connect Monitor
    After synchronisation, where can I see the HRV in the Garmin Connect Display??
    HRV
    Get the app.
    Graphing.
    Notes
    It can't see on your Garmin Connect website account, you can see your data inside the application or in the txt log file created by the application.
    Compatible with VAHR?
    I am interested in HRW and would really like to use it on my Vivoactive HR. Is this possible?
  • Forerunner 630 support
    Hi,
    Would it be possible to add the FR630 to the list of compatible watches?
    Thanks!
    Log file
    I see that you suggest he data file to make txt format. 'm not sure how to do that. Sorry. Could someone offer some help. Thanks!
    HRV, Forerunner 235 compatible
    Hi
    I'd really appreciate it if you could make this compatible with the Forerunner 235, might that be possible at all?
    Many thanks
    Lou
