WatchApp: Moxy App
Please post comments, problems, questions, and feature requests on the Moxy ConnectIQ App in this thread.
    I share your AGGGHHHHH.
    ConnectIQ does not yet allow Generic ANT data to be stored on the watch. The temporary work around is to get the .FIT file from the watch, and download the .FIT file from the Moxy sensor (using the Moxy PC App) and then merge the FIT files. Right now, the only merging option I know of is in Golden Cheetah but we will be releasing a merging option inside the Moxy PC App soon.
    Thx Roger...
    One more question please...
    How do I download the file .FIT in the Moxy PC APP?
    When I click on "Download Data" automatically stores a .CSV file
    By the way . I have been unable to download any training.
    This is the error that appears. I tried it on 2 different computers:
    and this is the text:
    Consulte el final de este mensaje para obtener más detalles sobre cómo invocar a la depuración
    Just-In-Time (JIT) en lugar de a este cuadro de diálogo.
    ************** Texto de la excepción **************
    System.OverflowException: Valor demasiado grande o demasiado pequeño para UInt16.
    en System.Convert.ToUInt16(Int32 value)
    en System.Single.System.IConvertible.ToUInt16(IFormatProvider provider)
    en System.Convert.ToUInt16(Object value)
    en Dynastream.Fit.Field.SetValue(Int32 index, Object value, Subfield subfield)
    en Dynastream.Fit.Mesg.SetFieldValue(Byte fieldNum, Int32 fieldArrayIndex, Object value, UInt16 subfieldIndex)
    en _2000118_MOxyPC.CFitFileWrite.BuildFitFile(String srcFile, String destFile)
    en _2000118_MOxyPC.FormMain.timerGetData_Tick(Object sender, EventArgs e)
    en System.Windows.Forms.Timer.OnTick(EventArgs e)
    en System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    en System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Ensamblados cargados **************
    mscorlib
    Versión del ensamblado: 4.0.0.0
    Versión Win32: 4.0.30319.1022 (RTMGDR.030319-1000)
    Código base: file:///c:/WINDOWS/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
    AppMOxyPC
    Versión del ensamblado: 1.0.0.0
    Versión Win32: 1.0.0.0
    Código base: file:///C:/Archivos%20de%20programa/MOxyMonitor/MOxyPC/AppMOxyPC.exe
    Versión Win32: 4.0.30319.1002 built by: RTMGDR
    Código base: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    Versión Win32: 4.0.30319.1001 built by: RTMGDR
    Código base: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System
    Código base: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.resources
    Versión Win32: 4.0.30319.1 built by: RTMRel
    Código base: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.resources/v4.0_4.0.0.0_es_b77a5c561934e089/System.resources.dll
    Accessibility
    Código base: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    System.Core
    Código base: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    mscorlib.resources
    Versión Win32: 4.0.30319.1 (RTMRel.030319-0100)
    Código base: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_es_b77a5c561934e089/mscorlib.resources.dll
    System.Windows.Forms.resources
    Código base: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_es_b77a5c561934e089/System.Windows.Forms.resources.dll
    ************** Depuración JIT **************
    Para habilitar la depuración Just In Time (JIT), el archivo de configuración de esta
    aplicación o equipo (machine.config) debe tener el
    valor jitDebugging establecido en la sección system.windows.forms.
    La aplicación también se debe compilar con la depuración
    habilitada
    Por ejemplo:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    Cuando esté habilitada la depuración JIT, cualquier excepción no controlada
    se enviará al depurador JIT registrado en el equipo
    en lugar de controlarlo mediante el cuadro de diálogo.
    Hi Roger.
    problem solved. I got an old PC vesion of Moxy APP .
    Now , I will follow the instructions UPDATE NOTES
    I still left the question of: .FIT & .CSV
    thx
    Roger,
    When I push start the Garmin crashes (and resets). But if I don't push start it reads live fine...but I can't record the file.
  • What device are you using, and what firmware version?
  • Hi rocketrichter,
    Sorry I'm slow to reply. I'm not able to reproduce that problem on my 920XT. There's an error log file that might help debug the problem. If you connect your watch to your computer with the charging cradle and navigate to the watch as if it's an external drive, there should be a file in the root directory called ERR_LOG.TXT.
    Can you PM that to me or post it here?
    Does the crash occur when the GPS is active or inactive (due to being indoors)?
    Thanks!!
    Roger
    Hi Roger
    Any word on when we will be able to record the sessions with MOXY - GARMIN IQ?
    THx
  • Any word on when we will be able to record the sessions with MOXY - GARMIN IQ?
    THx
    They haven't given me any commitment dates yet, just that it's on their roadmap. I expect it to be months rather than weeks or years.
    Roger
    M515Run: Difficulty setting 10k pace on FR 920
    Good afternoon everyone:
    I'm having a hard time trying to set my 10k race pace on the 515Run app in FR 920xt. When I enter 5:00 it accepts it but upon revision of the value it actaully sets it to 5:30. Same if I try to set it to, say, 4:30. So, my first question: does the app always use imperial units (I use metric) and why is it being set to 5:30 ? Thanks !!
    Marcos
  • Good afternoon everyone:
    Marcos
    Hi Marcos,
    The app uses the imperial / metric setting for PACE that's on the native portion of the watch. I think there's a separate setting for pace and distance.
    I think I'm seeing the issue with the pace setting not working in metric mode. I'll look into this more and get back to you.
    Roger
