**Capnia turns your Garmin into a dry apnea coach.** Built by a spearfisher and runner for freedivers who want to train CO2 tolerance on land — eyes closed, guided entirely by vibration.
**STATIC TABLES**
• CO2 table: constant hold, decreasing rest (e.g. 1:15 hold, 2:00 → 0:30 rest)
• O2 table: constant rest, increasing hold
• Max Hold (personal best) with live tracking
• Every parameter adjustable on the watch, saved between sessions
**CONTRACTION ANALYSIS (LAP button)**
• Press LAP at your first diaphragmatic contraction: Capnia switches from EASY HOLD to STRUGGLE and freezes your comfort time
• Every further press logs a contraction
• End-of-hold metrics: easy time, struggle ratio (%), contractions per minute, shortening of the interval between spasms
**BRADYCARDIA BIOFEEDBACK**
• Heart rate captured at the exact start of each hold
• Real-time ΔHR (start − current) and minimum HR
• 60-second heart-rate sparkline showing the dive reflex
**DYNAMIC FRC APNEAS (walking apneas)**
• Step-based sets: walk N steps → double vibration (passive exhale) → hold N steps on empty lungs → long vibration (breathe)
• Heart-rate cut-off (default 165 bpm): the hold stops immediately if it is exceeded
**RUNNING & LUNG CAPACITY**
• S1 – Z2 run with cadence coach (alert below 165 spm, 10 s rolling average)
• S2 – Hypoventilation intervals: 200 m with 4:4 breathing metronome and expiratory apnea on the last 15 strides, nasal recovery jog
• S3 – Post-run FRC walking apneas to stimulate the spleen
**EYES-CLOSED HAPTICS**
Short pulses at T-3, T-2, T-1, long vibration at T-0, continuous vibration at T+15 s of recovery to force safety breaths. LAP never exits a session by accident.
**GARMIN CONNECT DATA**
Each hold is saved as a lap with custom fields: phase, contraction count, bradycardia drop, struggle ratio and steps in apnea.
Languages: English, Français, Italiano.
**SAFETY — DRY TRAINING ONLY.** Never practise breath-holding in or near water alone. Breath-hold training can cause loss of consciousness: always train seated or lying down for static holds, on safe ground for walking apneas, and stop at the first warning sign. Capnia is not a medical device and does not replace a qualified instructor or a buddy. Consult a doctor if you have any cardiovascular or respiratory condition.
