I've recreated one of my favourite Pebble watchfaces on CIQ, Nyan Cat;
https://apps.garmin.com/en-US/apps/c8f5e260-6a54-4f3a-a910-c10d7cc37778
I built this to explore sprite animation in Monkey C. My initial attempt was to use a number of bitmaps to represent the animation. However, I quickly hit the 64k memory limit with 12x bitmaps (4-bit colour).
I then explored the following;
- Using a series of Font Glyphs to represent the sprite animation.
- Manually draw sprites from colour integers in a series of arrays.
- Manually draw sprites using strings and a palette map.
Here's an example of the manual sprite routines:
[PHP]const nyan_data = "xxxxxxxxx00000000000000000xxxxxxxxxxxxxxxx0eeeeeeeeeeeeeeeee0xxxxxxxxxxxxxx0eeedddddddddddddeee0xxxxxxxxxxxxx0eeddddddaddadddddee0xxxxxxxxxxxxx0eddadddddddddddddde0xxxxxxxxxxxxx0edddddddddd00ddadde0x00xxxxxxxxxx0eddddddddd0bb0dddde00bb0xxx0000xx0eddddddadd0bbb0ddde0bbb0xxx0bb00x0eddddddddd0bbbb0000bbbb0xxx00bb000edddaddddd0bbbbbbbbbbbb0xxxx00bb00eddddddda0bbbbbbbbbbbbbb0xxxx00bb0edadddddd0bbbz0bbbbbz0bb0xxxxx0000edddddddd0bbb00bbb0b00bb0xxxxxxx00edddddadd0bccbbbbbbbbbcc0xxxxxxxx0eedaddddd0bccb0bb0bb0bcc0xxxxxxxx0eeeddddddd0bbb0000000bb0xxxxxxxx000eeeeeeeeee0bbbbbbbbbb0xxxxxxxx0bbb000000000000000000000xxxxxxxxx0bb00x0bb0xxxxx0bb0x0bb0xxxxxxxxxx0000xx000xxxxxxx000xx00xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
const palette = {"0" => 0, "a" => 11141120, "b" => 11184810, "c" => 16711680, "d" => 16711935, "e" => 16755200, "x" => Gfx.COLOR_TRANSPARENT, "z" => 16777215 };
// sprite_data = uses a char string + pallete to draw a sprite
function drawSpriteText( x, y, sprite_data, sprite_width, sprite_height, dc ) {
var old_x = x;
var size = sq_size;
var sprite_colour = 0;
var sprite_val = "";
for( var j = 0; j < sprite_height*sprite_width; j=j+sprite_width ) {
for( var i = 0; i < sprite_width ; i++ ){
sprite_val = sprite_data.substring(j+i,j+i+1);
sprite_colour = palette[sprite_val];
dc.setColor(sprite_colour, Gfx.COLOR_TRANSPARENT);
dc.fillRectangle(x, y, size, size);
x = x + size;
// on to the next sprite row
y = y + size;
x = old_x;
// draw the sprite
drawSpriteText(x_pos, y_pos, nyan_data, sprite_height, sprite_width, dc);
[/PHP]
All these options worked, and kept the watchface within memory limits - except they are slow.
Running hundreds of dc.fillRectangle fills are expensive, and the watchface could only update once a second.
My last option was to manually animate the sprite using a number of different bitmaps.
Here's the source code if anyones interested:
https://github.com/sunpazed/garmin-nyan-cat
I'd be keen if anyone has any other clever ideas on how to implement sprite animation.
