Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • Version 4.4
    I've just released version ActiFace 4.4 with these changes:
    - added timezone offset configuration for second time field
    - added daylight saving time correction for second time field
    - added climbed floors custom field for supported devices (CIQ 2.1)
    - added climbed meters/feet custom field for supported devices (CIQ2.1)
    - added descended meters/feet custom field for supported devices (CIQ2.1)
    - added week intensity minutes percentage custom field (CIQ2.1)
    - added "Day DD Month" date format
    - changed 24h time format to always show 2-digit hour number (i.e. 09:35)
    Can somebody, please, update it and let me know if everything is going right? I did a lot of tests, but I don't have all supported devices with all possible firmwares :) Thank you.
  • Woohoo!
    "Climbed Floors" works like a charm @vivoactive HR!
    Thank you so much! :)
    Edit: hours remains a single digit, if smaller than 10
    All going well on a VivoActive HR. No problems found except I cannot see a Month Day DD only the previous selections.
  • All going well on a VivoActive HR. No problems found except I cannot see a Month Day DD only the previous selections.
    "Month Day DD" is too long for fields on Vivoactive HR.
  • Version 4.5
    - improved and anti-aliased time font on FR230/235/630/735, Vivoactive HR and Epix
    - minor bug fixes
    I have now lost all my options for day and month displays and even Day DD no longer displays.
    With the latest update I have lost my day and date that used to work in Day DD format. I have restarted my watch but it remains missing.
    With the latest update I have lost my Day DD display completely on my Vivoactive HR. I have restarted my watch but it has not returned.
  • With the latest update I have lost my Day DD display completely on my Vivoactive HR. I have restarted my watch but it has not returned.
    You are right, I accidentally changed the font color for date to the same as background.. so it was there, but invisible :) Check out the latest build 4.5.3, it should be fixed. You'll also see a little thicker time font on VVAHR.
    Thanks
    Thanks so much it is back.
    I am happy to be a Vivoactive HR tester for you if you would like!
