Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • The step progress is tracked on the Fēnix 3 by the arc below the step count figure. It is filled in grey until you hit target and then turns green.
    Bars at the left are your "move" indicators - more bars means less movement has taken place in the last hour (or whatever it is)
  • Bars at the left are your "move" indicators - more bars means less movement has taken place in the last hour (or whatever it is)
    thanks! I figured that out ... in detail I'd like to understand: what does the left bar from 40 to 45 min tell me? From 45 to 50: that one gets larger (and is "dotted") with inactivity. The lower part: is it just some yes/no for inactivity?
    It ain't important, but nice to know ;-)
  • thanks! I figured that out ... in detail I'd like to understand: what does the left bar from 40 to 45 min tell me? From 45 to 50: that one gets larger (and is "dotted") with inactivity. The lower part: is it just some yes/no for inactivity?
    Pretty much as you said - it's the inactivity bar (I don't remember the exact detail - I turned off the move alert when I got back from 100km bike ride and it told me to move!)
  • can't install ActiFace, no '3 dots' in Garmin Express
    Hi i'm a new Fenix 3 HR user, installed Garmin Express 4.1.28.0 on my Windows 10 laptop, and there are no '3 dots' next to any of the watch faces (or anything else).
    any idea how to fix this?
    thanks
    Faron
  • Pretty much as you said - it's the inactivity bar (I don't remember the exact detail - I turned off the move alert when I got back from 100km bike ride and it told me to move!)
    same experience here ;-)
  • Hi i'm a new Fenix 3 HR user, installed Garmin Express 4.1.28.0 on my Windows 10 laptop, and there are no '3 dots' next to any of the watch faces (or anything else). any idea how to fix this?
    Yes, right click, then SETTINGS :)
  • Minor note, i see in the log, the following message many times. Perhaps the Store_ID indicates it comes from this app i believe, that id was mentioned elsewhere in this thread.
    "I:\Garmin\Apps\Logs\CIQ_LOG.TXT"
    WARNING: Unable to close bike power sensor
    STORE_ID: 7ef071c34a144eb3aca9e3a531262711
    This other thread seems to relate to the issue and maybe a correction
    https://forums.garmin.com/archive/index.php/t-333428.html
    Former Member over 8 years ago
    Hello!
    Some ideas from user Garmin-920:
    1) Make the indentation before the day of week.
    Now the first vertical line of the weekday name merges with the boundary of clock.
    2) After sunset, the clock does not change the time of sunset to sunrise.
    I have to do it manually - taking a lock, and again putting on the block.
    3) Well to make the ability to put on a different field separately - sunrise and sunset separately.
    Examples can be seen in the photo:
    https://yadi.sk/i/pP9ILr-3wS4gH
    https://yadi.sk/i/LBHbS_HEwS4iy
    https://yadi.sk/i/WY2-NstvwS4mS
  • thanks...can you update page one?
    thanks, that did it. However i was using the steps from page one of this thread (ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
    Here is how to do it: https://forums.garmin.com/showthread...o-App-Settings) where it says to click the 3 dots, any chance that could be removed/updated?
    thank you!
    Faron
  • Floor climbed?
    Awesome watch face, good job!
    Is it possible to have floor climbed data field?
    Thank you
