Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • Just a personal experiment - ActiFace in Outdoor Mode with Elevation profile..
    Perfect - this is very interesting for me.
    Former Member over 9 years ago
    4324
    Awesome Peter. Thank you for incorporating this feature/request! Keep up the great work sir. Cheers
    As you wish.. ;)
  • Feature Request: Show Heart Rate
    Hi Im using you watchface from the beginning on my F3 and love it
    last week I upgraded to F3HR
    Please implement the feature to show HR
    I konw that it is possible to show HR
    could you implement this feature to show HR in your watchface... I know it's only for F3HR users but if you can make it otional this would be great
    Edit: It must not shown the HR graph, the current HR value is sufficiant maybe as an additional option instead of Sunset Time
    I'm sorry if this feature request is a repeat from earlier in these many pages, but I would love to be able to turn off the calorie counting features. I'm not interested in tracking calories (in fact, I'm sort of actively interested in not caring about calories) and that would simplify the screen down to the info I want to see. Thanks for this watchface!
  • Actiface on Fenix 3 HR with Altitude display
    Hi Peter I have fenix 3 HR.
    Hi Peter
    I have searched the F3 HR and nowhere can I find elevation unit settings other than in Setting>System>Units. Which I have tried to change from ft to m and back again. But this does not update the ActiFace units which remain set = ft, regardless of what unit is selected in Settings.
    Can you please look at this again for model F3 HR and let me know where/how I should correct for this?
    Many thanks.
    BR
    David
    Can't show the color graph column for past 7 days?
    As title. Have been using this watchface for months and loving it. But the 7-days column for daily steps has gone ever since I updated my fr 235 to FW4.2 and ActiFace to 4.1 today. Watch language is Traditional Chinese. Pls help. Thank you very much.
  • As title. Have been using this watchface for months and loving it. But the 7-days column for daily steps has gone ever since I updated my fr 235 to FW4.2 and ActiFace to 4.1 today. Watch language is Traditional Chinese. Pls help. Thank you very much.
    Hi,
    it (fw update) probably removed your activity tracker history. I believe that it will get filled in next days, but the lost data cannot be restored.
  • Hi Peter
    Many thanks.
    BR
    David
    Hi David,
    I found an incorrect handling of distance vs. elevation units in my code. Thanks for reporting it. Fix is already available in version 4.1.1.
    Hi Peter
    Many thanks.
    BR
    David
    Hi Petr, many thanks for fixing the altitude unit issue. I received the update this morning and now I see m instead of ft.
    BR
    David Potter
    Suggestion pour le graphique
    Une suggestion pour le graphique : permettre la visualisation en nombre d'heures d'activité (en plus de la distance, ou le nombre de pas).
    Demande justifiée par le fait qu'une séance de natation de 3 kilomètres disparaît complètement si la veille on a fait 80 kilomètres en vélo ou même seulement 20 kilomètres de course à pied. C'est dommage et fausse complètement la lisibilité du graphique.
    One suggestion for the chart: allow viewing in hours of activity (in addition to the distance, or the number of steps).
    Demand justified by the fact that a 3 km swim session disappears completely if the day we did 80 kilometers by bike or even just 20 kilometers from running. This is unfortunate and completely false readability of the chart.
