Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • Hi Peter
    Excellent Watch face by the way. Can I report what I believe is a bug. No matter what I try the altitude units symbol describes FT (Feet) when I have the watch system units set = M (Metres). Can this be solved please.
    The numbers are correct, just the elevation unit is displayed incorrectly
    Many thanks
    David Potter
    Hi, which model do you have? There are system distance units in the settings, but elevation units are separately, can you check if you have se meter also for the elevation? Thanks
  • Hi, which model do you have? There are system distance units in the settings, but elevation units are separately, can you check if you have se meter also for the elevation? Thanks
    Hi Peter I have fenix 3 HR.
  • different calorie value spent compared to Connect
    love the watchface and has been using it as my default one! just noticed something today, the calorie graph/counter on the watch with Actiface is showing different values than the one from Connect for yesterday. On the watch it's showing 3035 and on the Connect it's showing 3613 total. My workout session did extend 30min past midnight though, could it be related and fixed? thanks
    I have used this watch face from day 1 and love it. I have tried others but have always gone back to this watch face, so kuddos to you and keep up the good work. My only feature request along with Poly65 is a light background version. Would love the ability to change the background white/black and the font color and data field color.
    Hi Peter. I would like to see like once a variant with a light background. Mir depends dark color slowly to his neck out, I can not see them, I need once again a change. Even at the Fenix you can change the background, unfortunately, does not work with the Epix. I would be delighted if soon your popular watch comes with a light background. There simply is no better than your watch. ;-)
    Just a personal experiment - ActiFace in Outdoor Mode with Elevation profile..
    Loving this. Is it possible?
  • Loving this. Is it possible?
    It's still not very usable at this time. Too many points in the graph are causing very slow responses.. I'd like to decrease the number of ALT measurements (i.e. one per 5 minutes) and will see if it gets better.
  • [QUOTE=Khoi Q. Pham;830252]I have used this watch face from day 1 and love it. I have tried others but have always gone back to this watch face, so kuddos to you and keep up the good work. My only feature request along with Poly65 is a light background version. Would love the ability to change the background white/black and the font color and data field color.
    As you wish.. ;)
    Nice. Hope it works out as I'd definitely like it as an option, if possible.
  • The inverted display looks nice on the pictures.
    However, on my fenix 3 HR I can not see the new inverted view
    In app settings I activated the "Inverted mode" but it seems that this has no effect on the display.
    Any other parameter or dependency necessary?
  • Ok, restart of the fenix helps me - inverted mode is now visible
