Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
    Former Member over 9 years ago
    Thanks
    Screenshots on download page were made in the simulator on the PC so colors are significantly brighter than colors on transflective display. Additionally, each device has a little different brightness. To me, the best colors and the most readable display has FR920XT.
    Thanks for your response. I do have the FR920XT and it is an awesome watchface you created. As far as the Red Z's go, are they only disabled by doing some type of activity?
  • As far as the Red Z's go, are they only disabled by doing some type of activity?
    Thanks. The logic of ZZ's is fully managed by watch firmware and it's typically related to steps. It starts to increasing the inactivity level after hour of inactivity and then add 1 level per 15 minutes. But I believe that inactivity alert can be removed also with a swimming (but I didn't try it) :)
    Confirme (désolé en français) : toute activité sportive, piscine ou salle, remet la barre d'activités à zéro
    Arrows underneath Clock
    Underneath the Clock there are two arrows. What does the white one on the far left represent? I know it is in miles, but is it miles for the day, or miles for the week? I know the blue one is the calories I believe? Thanks.
  • How to turn off "zzzz"
    I am new to this forum and only have been using this awesome app for a few days, so I apologize if this question is redundant;
    How do i turn off the "zzzz" mode for when i get up from desk job and start walking around? I doesn't seem to get out of this mode by simply starting to move. Any support I can get would be most appreciated,.!
  • "zzzz" mode is based on the standard activity tracker - so moving around for a couple of minutes will reset it. Being idle will make the zs count up...
  • ActiFace 2.0
    - with new features
    - user-configurable via Garmin Connect Mobile and Garmin Express
    - powered by ConnectIQ 1.2
  • ActiFace 2.0
    How do I get ActiFace 2.0?
    I'm on SDK 1.2, Fenix 3 - 6.06 Beta Release.
    Which are the new features? Can you be more specific?
    Thx
  • How do I get ActiFace 2.0?
    Thx
    I can make it public when CIQ SDK 1.2.0 will become final as well as new versions of Garmin Connect Mobile and Garmin Express.
    New features are mostly related to configuration:
    - you can choose the color (blue, red, yellow, green, purple, pink, orange)
    - you can choose graph description - options are week maximums (currently displayed with up-arrows), week averages and week totals
    - you can choose if the white line shows distance or steps
    - there is a new notification icon with a number of unread messages/calls/notifications
    - alarm icon
    - and finally you can switch the color graph from calories to 24-hour stepqualizer which shows your step activity for the past 24 h as equalizer (you can see something like that on epix image I posted yesterday) - but this feature is still in development and I'm not sure if it will be available in v2.0 or later
    - I also had a lot of work with a layout for new types of display geometry
  • You did it again mister!
    Beautiful and full of data for us :D
    Cant wait to update. You are one of the few developers here to take this store to a very pleasing level ,
    thank you.
