Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
    Former Member over 9 years ago
    percentage goal
    Hello
    I think what is missing for fenix 3 is the percentage daily goal. Do u think is it possible to add the steps in percentage with daily goal in lower or higher mode. In this way while looking to the watch we can see our daily percentage steps with its daily goal needed to achieve . I think in this way the app will be PERFECT
    THANK U
    Hello
    is it possible to add the percentage daily steps with its daily goal in lower or higher mode.
    Thank u
    Great app!
    Thanks for this great watchface, you managed to show all the information I want in a very clean way and the graph is a great motivator, this should be Garmin’s default…
    I only have a very small suggestion, on the red face the digits indicating the daily kC are red and in the VA the contrast is to low making it impossible to read, you should set this white like the rest of the text.
    Wishlist
    Here is my wishlist for future versions:
    -Alarm icon
    -Hour font is too thick (IMO). Maybe the font could be the same as the Epix's default.
    Thanks
    Active History Graph Resets Every Day
    Any suggestions on this one? Using the 920XT. I've reinstalled after a factory reset on the watch.
  • Hello
    THANK U
    Hi, the percentage is expressed graphically by the increasing bar below steps.
  • Any suggestions on this one? Using the 920XT. I've reinstalled after a factory reset on the watch.
    You can try Menu > History > Settings > Reset Defaults..
  • Here is my wishlist for future versions:
    -Alarm icon
    Thanks
    Hi,
    thanks for you suggestions. I'd like to add an alarm icon but watchfaces don't have alarm settings available in the current version of Connect IQ.
    I'll make fonts thinner on Epix in the next release.
  • Thanks for this great watchface, you managed to show all the information I want in a very clean way and the graph is a great motivator, this should be Garmin’s default…
    Good appointment. I'll try to change the kcal color for Vivoactive.
    I love this watchface...thank you for all the time and effort you've invested.
    I have a Fenix 3, FW 3.80. The distance indicator on the left of the screen hand the kcal indicator on the right have not changed in a few days (the figures immediately above the graph). I thought they represented the prior 6 day total. Is that not correct? The daily values change as expected. Any ideas on why these values seem to be "stuck”?
