Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • Yes, the white line shows your daily distance history, including activities. So you can have the peak in the day in which you walk only 1000 steps, if you got a ride as well. The distance is provided by device, it's not calculated in ActiFace. You can check these values in Menu > History > Steps. There are lot of possibilities what to show in the graph but there is still no configuration possibility and I had to make compromise. I chose a distance because it better describe your activity than just steps, especially if you are cycling.. Of course, it has some disadvantages, for example if you combine running and cycling. It might be the best to show third line - steps, but it could be really overcrowded.
    Former Member over 9 years ago
    Please have some different colors for the times
    ActiFace Blue
    ActiFace Red
    Version: 1.7.4 (05.06.2015)
    - Time
    - Date
    - activity history graph (past 6 days + today) in kCal and km/mi
    - maximum kCal and km/mi
    - daily goal circle graph + step count
    - today's distance
    - today's calories
    - battery status icon + percentage
    - sleep mode icon
    - bluetooth icon
    - muted sound alerts icon
    Please, share your screenshots if you see any graphic errors.
    Watchface was optimalized for low power consumption.
    Changes:
    v 1.1
    - added battery percentage
    - added distance graph
    v 1.1.1
    - fixed wrong graph direction
    v 1.1.2
    - fixed graph grid positioning
    - battery is now green between 55% and 100% (was 70% and more)
    - support for high power/low power mode (only for FW 3.03 and newer)
    - added runner icon into goal circle for 3 seconds if you look at the watch during longer inactivity (FW 3.03 and newer)
    v 1.2
    - added bluetooth icon
    v 1.2.2
    - backward compatibility witch older firmware versions
    v 1.2.3
    - fixed crashing on older firmwares due to memory leak caused by SDK 1.0.0
    - small tweaks
    v 1.3
    - added icon for muted sound alerts
    - graph lines are bolder for 2 seconds when you take a look at the watch
    - small icon improvements
    v 1.4
    - design improvements and fixes for Vivoactive
    - bolder graph line
    v 1.4.1
    - fixed today stats positioning
    - added Fenix 3 support beta (fw 3.10)
    v 1.5.2
    - added inactivity indicators
    - small UI changes and corrections
    v 1.6
    - improved circle graph
    - optimalizations
    - added battery percentage for Fenix3
    - small design corrections
    v 1.6.1
    - Fenix 3 only: battery percentage is shown only if you look at the screen (text over battery was hard to read on F3)
    - Fenix 3 only: graph design tweaks
    - small optimalizations
    v 1.6.2
    - removes grey ends of the graph on Fenix3 (it collidated with inactivity indicator)
    v 1.6.3
    - battery rendering optimalization
    - circle graph rendering optimalization (on square screens)
    - decreased memory requirements by using shared components for square and circle version
    - fixed battery percentage was too close to BT icon when charged to 100% (on Fenix3)
    - fixed 'mute' icon was always shown on Vivoactive
    v 1.7
    - redesigned graph
    - improved step counter on Fenix3 (for better readibility)
    - changed inactivity indicator in rectangle screen version
    - small design tweaks
    - graph data are computed each 5 minutes for better energy efficiency
    v 1.7.1
    - small design fixes
    v 1.7.2
    - the goal progress bar now changes color to green when you reached the goal (on Fenix3)
    - added "goal reached" indicator into the week graph (small green triangle) - indicates days when you reached your goal for that day
    - week history graph in the square version was extended by 1 day to be equal with F3 version
    v 1.7.3
    - added custom font for time field on Epix because font in the simulator doesn't correspond to the real one (it'll be adjusted when I get my own Epix)
    v 1.7.4
    - tuned for Epix
    - small design improvements (especially for Fenix3)
    I think it will great if you could change the minutes in red or orange. I would be really appreciate for doing this. Btw you developer did an awesome job on this. I hope to see more watch faces similar to this. Thanks again.
  • and I like houres + minutes in white.
    The next One prefer green.
    In my opinion, the developer should not implement ANY individual colors
    true...
    perfect the way it is
    I don't know if somebody else already requested it, but i have a small request.
    Currently you see a line in the graph with the distance you made in your previously 7 days. Is it possible to change that to time spend on a workout. Because the difference between swim distance and bike distance are huge, and if you show time it will be more equal.
  • You're definitely right, time spent in activities is a good indicator. But there are two things.. 1) Connect IQ doesn't provide this information to the watchfaces.. 2) to the distance are also counted other steps, not just from sport activities, so if you have a busy day with lot of steps, it's the activity as well
  • Badges
    I'm thinking about some kind of badges for ActiFace. I found a space on the screen for them (same plase as zzzzz if you don't have any inactivity level on 920XT, or above today's distance/calories on F3). Up to three badges.
    An example: you've reached 4 goals in last 5 days including today.. or you've reached 7 goals in last 8 days including today.. or you've doubled your today goal.. or you've got a week maximum distance today..
    Can it be interesting for you, or it would make the screen overcrowded? There is also an option to do that only for square version, because there'll still be enough space for potential new icons in the upper line. The icon area on Fenix3 is very limited by circle display.
    Thanks for your feedback..
  • ok, hopefully this isnt too crazy big.
    so i have a qustion.. the little arrows at the bottom, what are they? in many of your images there are significantly more vertical lines and not all of them have the triangles at the bottom. are those my activities? also, mine are white, others ive seen are green? just curious. this is a really kickass watch face and thank you for making it. its a little busy but super functional. A+
    i have to laugh that i have 4 z's here after 12,000 steps today. im going to develop a complex! :p
  • Hi and thanks,
    these white triangles just indicates days when you reached your goal. They were originally green, now they are white because of visibility.
  • Very good
    Fenix 3, firmware 3.60. I noticed that there is no procent for battery (at least not in Fenix 3).
    Not sure how to read the graphs. There are 4 vertical grids and on the third there is a small white triangle at the bottom. Each vertical grid marks 2 days? The white triangle marks thr maximum?
    Edit: actually the graph doesn't seem to work. It shows the same thing always.
    Why two faces instead of one with color option? When I install one it replaces the other one. So is not easy to change.
