Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • Icono del tiempo / icono clima
    Seria buena idea poner icono del tiempo / icono del clima . Comprendo que es dificil pero seria lo mejor o bien autodectar ubicacion o elegir zona. Habeis hecho un magnifico trabajo. Me encanta.
  • Can I change the font back to the previous one? Im using Epix, thanks!
    Former Member over 10 years ago
    I want to ActiFace Green
    Former Member over 9 years ago
    I downloaded to my 920XT today and nothing changed on my display. I restarted my watch and that did not help.
  • I downloaded to my 920XT today and nothing changed on my display. I restarted my watch and that did not help.
    did you choose it in settings?
    System/Clock/Watch Face
    This is it!! I like green!!
    Like this?
    This is it!!
    I like green!
  • seconds
    My favorite watchface. It would be Nice to See seconds
    Acti
    ActiFace Red
    Version: 1.8.2 (12.08.2015)
    - Time and date
    - activity history graph (past 6 days + today) in kCal and km/mi
    - maximum kCal and km/mi
    - daily goal circle graph + step count
    - today's distance
    - today's calories
    - battery status icon + percentage
    - sleep mode icon
    - bluetooth icon
    - muted sound alerts icon
    Badges:
     - you've reached the week maximum distance
     - you've doubled your step goal
     - you've reached the goal 4 times in a row in past 5 days (including today)
     - you've reached the goal 7 times in a row in past 8 days (including today)
    Please, share your screenshots if you see any graphic errors.
    Watchface was optimalized for low power consumption.
    Changes:
    v 1.1
    - added battery percentage
    - added distance graph
    v 1.1.1
    - fixed wrong graph direction
    v 1.1.2
    - fixed graph grid positioning
    - battery is now green between 55% and 100% (was 70% and more)
    - support for high power/low power mode (only for FW 3.03 and newer)
    - added runner icon into goal circle for 3 seconds if you look at the watch during longer inactivity (FW 3.03 and newer)
    v 1.2
    - added bluetooth icon
    v 1.2.2
    - backward compatibility witch older firmware versions
    v 1.2.3
    - fixed crashing on older firmwares due to memory leak caused by SDK 1.0.0
    - small tweaks
    v 1.3
    - added icon for muted sound alerts
    - graph lines are bolder for 2 seconds when you take a look at the watch
    - small icon improvements
    v 1.4
    - design improvements and fixes for Vivoactive
    - bolder graph line
    v 1.4.1
    - fixed today stats positioning
    - added Fenix 3 support beta (fw 3.10)
    v 1.5.2
    - added inactivity indicators
    - small UI changes and corrections
    v 1.6
    - improved circle graph
    - optimalizations
    - added battery percentage for Fenix3
    - small design corrections
    v 1.6.1
    - Fenix 3 only: battery percentage is shown only if you look at the screen (text over battery was hard to read on F3)
    - Fenix 3 only: graph design tweaks
    - small optimalizations
    v 1.6.2
    - removes grey ends of the graph on Fenix3 (it collidated with inactivity indicator)
    v 1.6.3
    - battery rendering optimalization
    - circle graph rendering optimalization (on square screens)
    - decreased memory requirements by using shared components for square and circle version
    - fixed battery percentage was too close to BT icon when charged to 100% (on Fenix3)
    - fixed 'mute' icon was always shown on Vivoactive
    v 1.7
    - redesigned graph
    - improved step counter on Fenix3 (for better readibility)
    - changed inactivity indicator in rectangle screen version
    - small design tweaks
    - graph data are computed each 5 minutes for better energy efficiency
    v 1.7.1
    - small design fixes
    v 1.7.2
    - the goal progress bar now changes color to green when you reached the goal (on Fenix3)
    - added "goal reached" indicator into the week graph (small green triangle) - indicates days when you reached your goal for that day
    - week history graph in the square version was extended by 1 day to be equal with F3 version
    v 1.7.3
    - added custom font for time field on Epix because font in the simulator doesn't correspond to the real one (it'll be adjusted when I get my own Epix)
    v 1.7.4
    - tuned for Epix
    - small design improvements (especially for Fenix3)
    v 1.8
    - added badges
    - added Bravo D2 compatibility
    - changed time font for Epix
    v 1.8.1
    - Epix time font is now standard Roboto
    v 1.8.2
    - today stats are completely in white for better visibility
    - added white and color arrow next to maximums as graph color legend
  • My favorite watchface. It would be Nice to See seconds
    read #252
  • Like this?
    Cool!
    When can we download this from within the app store?
