Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
    hello
    I have the fenix 3
    Lulla I left five red dots in verticlare.
    What are?
    thanks
    gimmy
  • I think you should change graph data are computed each 5 minutes to 30 minutes or 1 hours or more because i don't think anyboby want to look graph data every 5 minutes. I feel that this watch face is using a lot of battery for now. Please fix it. That my suggestion for now. I will have more suggestions if you would like to have it. Thanks
    Hi, I did tests and comparison of ActiFace and default watchface and didn't notice any difference. In fact, graph is refreshed each minute, only data are recomputed once per 5 minutes for faster rendering if you scroll through screens. Changing to 30 minutes or more will not improve battery life. Moreover, it can bring negative effect if your currect daily distance is a maximum at the same time, this will not be projected to the graph for 30 minutes or hour and data will be incorrect. To me, 5 minutes is good compromise.
  • hello
    I have the fenix 3
    What are?
    thanks
    gimmy
    Hi, five red dots on the left mean that you reached maximal level of inactivity. Just move to remove it:)
    great
    Ty
    hello
    I have Fenix 3
    You 'can get more details about the two graphics overlap?
    The red one (full color)
    The white one (linear)
    How are the details?
    Ty
    Gimmy
  • I DONT WANT TO SPAM YOUR INBOX
    Just wanted to say great work and thank you for the actiface skin!!!
    fenix3 user and red skin.
    is there any plan to make more color skins?
    would be very nice!!! green and yellow will be nice (go along with the fenix 3 color bands :D)
    have a good day sir!
    I had v 1.6.3 with FR920XT 3.30 and it worked fine. (And looked fine too) :D
    UUnfortunately I activated auto update for APPs, so I got a new version of ActiFace Blue. My app says, that it is installed, but my display looks like out of the box and this is really ugly. Tryed to deinstall and install again, but display does not change...
    Could you please fix the Problem asap, dont like the standard face...
    Greets! And thanks for great Watchface!
    Solved the Problem. As I installed a second Watchface, now I can change to Actiface in clock settings...
  • Solved the Problem. As I installed a second Watchface, now I can change to Actiface in clock settings...
    Thanks for information.
    Love this watch face! :-)
    Great work!
    Had a problem today (though it may or may not be a watchface problem):
    I completed a bike ride and saved the activity.
    A few minutes later, I noticed that the F3 was rebooting. After rebooting, it showed 1.3 miles for the day but the bike ride was 12 miles.
    I found the ride in the history, so it was successfully saved.
    Tried rebooting the watch again, but the total distance on the Actiface Red still excluded the cycling activity.
    So, it appears that an error occurred -- perhaps with the Actiface Red watch face? -- and it isn't getting the cumulative miles value from the F3 now.
