Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
    "Do not disturb" on vivoactive HR
    Thank you for this awesome watchface! I love it, but I would love it even more if there were an icon showing whether "do not disturb" is on or off on the vivoactive HR. Please consider it in a future update :)
    Error with automatic time update
    Worked fine first of all. Watch crashed reset and now wants to show 1300 when it's actually 1600. Any ideas? I know you can manually set which I will do for now but would be better if it auto updates.
    Great watch face though well thought out
  • Worked fine first of all. Watch crashed reset and now wants to show 1300 when it's actually 1600. Any ideas? I know you can manually set which I will do for now but would be better if it auto updates.
    Hi, just fix GPS.
    I would like to add meteo icon (near sunrise/sunset) and have the barometer in white line, very useful to understand the forecast immediately... without to know the value of the pressure.
    And switch the graph from calorie to steps or distance...
    thanks
    example of graph pressure indicator
    please help vivoactive hr user!
    Hi guys, I'm using vivoactive hr. When my FW is 2.7, everthing is fine. However, after upgrade to 3.0, my sunset/sun rise time did not display at all. I tried several ways including restart the watch or reconfigure the setting and its still the same.
    Please help me!
    Fénix 3 HR bad performance
    I love how the screen looks but the performance of the clock (fenix 3 HR) becomes very poor. Sometimes I press a button and nothing happens until 2-3 seconds later.
    Is this the expected performance?
    Help
  • The ActiFace is doing a lot of calculations which are performed during swipe between screens and it can make it slower on some older devices. Newer devices make better job here and swipes are pretty smooth. I did a bunch of optimizations but there are hardware limitations I'm not able to overcome.
    Great
    Works great on vivoactive HR but would be nice if you could edit some stuff yourself (like colors)
  • Works great on vivoactive HR but would be nice if you could edit some stuff yourself (like colors)
    I have no problems to change colors and other stuff on Vicoactive and 920XT.
    You know, that changing in Garmin Express is possible?
