Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • Here is the description.. It's also in gallery on CIQ Store ActiFace page.
  • It creates a new column on the right and shift the rest of the graph to the left at midnight.
  • ...as usual,
    like this one in all of its flavours on Vivoactive/HR and fenix:
    Cheers
    VS
  • also does anyone know if we can alter the colour of the various texts? Some colour can really make a watch face pop
    wrong thread?
    This seems not to be the Actiface watchface...
  • ...as usual,
    Cheers
    VS
    Good spot ;)
  • This is exactly what I was about to ask for.
    For example, and I know I only got my Vivoactive yesterday but what does the kC signify?
    Mines showing 2719kC, however I have set up Connect with MFP and it shows my daily allowance as 2200kC.
    Is the 2719kC what I would need to consume to stay at the weight I am?
    In a nutshell I want to lose weight and need it to say what cals I have left once I log on MFP.
    Is this possible?
    Thanks,
    Al
    I have the forerunner 230 so I do not have the same layout as you. However, mine shows two numbers for kC. One is a constant value, the other changes during the day. I am assuming the one that is constant represents the highest amount you have burned during a one-day period and will change if you ever burn more than that. The other is of course the calories you have burned for the current day.
  • Exactly, one is Graph description value showing maximum, average or week total (it depends how you configured it), that's the value with the color icon. Values on the right side are actual for today, it's steps, distance and calories.
  • Hey Petr,
    Just want to say how much I like this face and I have a couple of questions.
    I have the Vivioactive and I have only had it a couple of weeks.
    The purpose of buying it was to aid weight loss so what I would like to see on the face would be calories burned for that day though exercise and also calories consumed that day (linked with my fitness pal).
    I don’t want it to add the calories burned through exercise to my daily eating calorie allowance.
    Does this make sense and is it possible?
    Thanks,
    Alan
  • Hi, I understand, but watchfaces actually don't have a possibility to differentiate between basal burned calories and activity calories. They're getting it counted together and that's what I can show you and put to the graph. Sorry.
    Thanks for the reply and no probs.
    I think I just need to understand what the watch can do.
    One thing I am confused about is its showing on the watch on the right hand side-
    1996kC – What is this number?
    On the Garmin Connect App I have the following info so I am not sure where the above number comes from –
    198kC Active/1128kC consumed
    2240kC goal (my calorie goal) + 198kC = 2438kC
    Calories remaining
    2438-1128=1310 remaining
    I am confused about what it’s showing here and on the watch.
    Are you able to explain?
