Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
    Former Member over 9 years ago
    Hi, ¿some guide of all icons in ActiFace 3.0?
    Thanks.
  • Hi, ¿some guide of all icons in ActiFace 3.0?
    Thanks.
    Was just looking for the same thing.
  • Activity bar thinner and disappearing , sunset /sunrise hidden when seconds appear
    the activity bar is thinner and not noticeable. Also there were times it wasn't shown yet I get notification it was cleared.
    The seconds of time when it appears make the sunset/sunrise info hide. Can you provide option with seconds and without ?
    Thanks for a great watch face ! :-) appreciate if the badge would go beyond just 7 in a day.
    Hi,
    only idea I have is that you can try to clear your CIQ apps and their settings. That means to delete everything in folder /GARMIN/APPS, including SETTINGS and DATA subdirectories.
    Then you can try to install it again.
    All right...it's working now!!
    Thanks a lot
    x2 think activity bar could be a bit bigger and/or give opt to remove completely. I notice the second and sunrise/sunset issue too
  • I notice the second and sunrise/sunset issue too
    I think it is not an issue.
    For me it is perfect, because no space is wasted
    Fenix 3 with fw 6.5
    Assuming you have a fenix3, what do you mean "is not working"?
    Works fine here through all beta versions and the current public 6.50
    When I change the watch face to actiface the screen starts blank and after a second or 2 the digital face become visible. There was no new updates since I checked this morning using Garmin Express.
  • When I change the watch face to actiface the screen starts blank and after a second or 2 the digital face become visible. There was no new updates since I checked this morning using Garmin Express.
    OK, first there is an update to the watchface since your first post. It's at V3.0 now. Worked fine with me for public V6.50 and now for beta V6.52
    First check if you have the latest Garmin Express software installed at your PC. If not, then update Garmin Express, configure ActiFace, and re-sync your Fenix 3.
    If that doesn't work, then try to remove and install again the watchface.
    If that doesn't work, then clear your CIQ apps and their settings. That means to delete everything in folder /GARMIN/APPS, including SETTINGS and DATA subdirectories.
    The last method was suggested by the dev at a previous post.
  • Dear users,
    I've just released version of ActiFace 3.1. It brings three changes.
    - fixed potential incorrect battery status percentage due to missing rounding up
    - seconds are now optional
    - rewritten internal graph data handling - now it saves its state into memory for the slightly faster return from another screen or menu
    Changes in third point were pretty huge and even if I tested it on all supported models, please report me all potential issues with graph updates or crashes.
    Thanks
    Dear users,
    Thanks
    Nice update! I see the activity bar is now removed. If that is planned I wonder if it would make sense to now move the days distance to the left side and just have the sunset/Cal's on the right.
    That would help shift the main time over to the center a bit and keep the daily and max distance on same side.
    Great work!
    Question. Did the update shift to kms instead of steps? Believe it used to say max steps and not max kms.
