Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
    Former Member over 9 years ago
    Hi, Do you mean 920XT? Have you the latest firmware 6.10?
    Confirme que c'est bien la Forerunner 920 et que la version du logiciel interne installée est la 6.10.
    A noter que les autres cadrans, y compris, ActiFace Red, n'ont pas ce genre de problème. Seule votre dernière version ne s'affiche pas automatiquement quand on revient soit d'un écran de notification, soit d'un écran d'enregistrement d'une séance de sport.
    Confirms that it is the Forerunner 920 and the version of the installed firmware is 6.10.
    Note that the other dials, including ActiFace Red, do not have this kind of problem. Only your latest version does not appear automatically when you come back either a notification screen, or a registration screen of a workout.
  • Hi Petr - I have the same issue - having changed the setting (in Express) from Curve to Bars (and nothing else) - Actiface no longer loads and I get dumped to the default face. Attempting to switch it back does not appear to fix it.
    Fenix 3 / 6.14beta (Display: 2.90 / GPS: 3.00 / BLE-ANT: 3.20 / WiFi: 2.00 / CIQ 1.2.1)
    I am seeing same issue on the 920XT with latest released 6.10 firmware. Set to anything but the default settings, and once I get a notification it dumps to the default watch face. Trying to reset the settings for the Actiface to default does not load it. I can only change the settings in the Garmin Connect Mobile app, they do not show in Garmin Express.
    Hi, have you also updated Garmin Express to the latest version? I'll check the notification count icon on the latest fw and let you know. Are you getting notifications from your phone generally?
    Yes to both....I've got the latest version of Express and my 920 is getting every notification through the iPhone as usual but actiface isn't showing any icon
  • fyi ActiFace (v2.0 and 2.0.2) are working perfectly for me with 920XT fw 6.10, including settings changes using GCM (v3.1) and notifications icon with iPhone 6s (iOS 9.0.2). Thank you for the updates!
  • V2.0.2 fixed the problem on Fenix 3.
    Thanks Petr
    Thanks Petr
    Looks like 2.02 works on the 920XT as well
    Thanks!
  • Many thanks to Kdelios for a lot of today testing.
    Update:
    Now is working like a charm also here, just done a new actiface upgrade through Express usb and now I'm getting notifications icon and setup from the pc...
    ....great!
  • sorry
    But with the Fenix 3 the apps not function .
    Ok ok
    Problème résolu avec la version 2.02. Tout fonctionne parfaitement. Les notifications apparaissent et le retour au cadran ne posent plus le moindre problème. Bravo pour la réactivité et grand merci
    Problem solved with version 2.02. Everything works perfectly. Notifications appear and return to dial no longer pose any problems. Bravo for responsiveness and great thank you
