I built this for my Wife. She quite often forgot to charge her Venu 3s battery and so I figured if i made an app/widget which would alert at a pre chosen level that would be a good idea.
She loved it immediately. It runs on many models, has a very light power usage and footprint. And it's really simple to setup. Download/install/set your level/ enable/ or disable alerts during sleep or exercise.........and just forget it ......
Grab it from the Garmin App store and give it a test run. I suggest setting the battery alert to 1% lower than what your battery is at for an initial test. Once the 'dismiss' screen pops you just tap the green tick which appears or the red x and it goes away. If you don't charge the watch it'll alert you again in one hour.
Any comments, suggestions etc will be very welcome !
apps.garmin.com/.../212544fd-980b-46ab-b8a2-eddc164dad6a
